[postgis-users] PostgreSQL 9.5 beta/PostGIS 2.2.0 fails with OGR
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 27 05:44:53 PDT 2015
I'm unable to reproduce any of this, though admittedly I'm not on a
9.5 install, but on a "9.6" (aka git master) install.
pramsey=# select '-1'::integer;
 int4
   -1
(1 row)
Crane:~/Sites/crackedtiles/pgsample pramsey(master)$ ogrinfo -q PG:"dbname=gis"
1: continent (Multi Polygon)
So, keep on investigating...
P
On Tue, Oct 27, 2015 at 2:49 AM, Chris Hill <chill at confusedsea.co.uk> wrote:
> Hi folks,
> I'm exploring Postgres 9.5 beta with PostGIS 2.20 (full versions listed
> below) on Windows 7 64 bit. All works as expected except for OGR which fails
> when attempting to access a PostGIS enabled database (but works for
> non-PostGIS databases).
> This command succeeds with Postgres 9.4 and PostGIS 2.1.7:
> C:\>ogrinfo -q PG:"dbname=postgis user=postgres port=5436"
> Whereas this fails on a new installation of Postgres 9.5 and PostGIS 2.2.0:
> C:\>ogrinfo -q PG:"dbname=postgis user=postgres port=5437"
> ERROR 1: ERROR:  invalid input syntax for integer: "'-1'::integer"
> FAILURE:
> Unable to open datasource `PG:dbname=postgis user=postgres port=5437' with
> the following drivers.
>   -> FileGDB
>   -> ESRI Shapefile
>   -> PostgreSQL
> As does any call to ogr2ogr. Yet this command succeeds:
> C:\>ogrinfo --config PG_LIST_ALL_TABLES YES PG:"dbname=postgis user=postgres
> port=5437"
> INFO: Open of `PG:dbname=postgis user=postgres port=5437'
>       using driver `PostgreSQL' successful.
> 1: tiger.loader_variables (None)
> 2: tiger.loader_lookuptables (None)
> 3: raster_columns
> This page http://www.gdal.org/drv_pg.html (see FAQs at the bottom) suggests
> that permissions on geometry_columns and/or spatial_ref_sys tables are the
> likely culprits, yet these tables appear to have full permissions granted
> for user postgres.
> Can anyone suggest a solution?
> Many thanks for any assistance.
> Chris
> -- Versions:
> PostgreSQL 9.5beta1, compiled by Visual C++ build 1800, 64-bit
> POSTGIS="2.2.0 r14208" GEOS="3.5.0-CAPI-1.9.0 r4090" SFCGAL="1.2.0"
> PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.0.1, released 2015/09/15"
> LIBXML="2.7.8" LIBJSON="0.12" TOPOLOGY RASTER
> GDAL 1.11.3, released 2015/09/16
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
