[postgis-users] Trouble compiling PostGIS 2.2.0 with raster support
Havard Tveite
havard.tveite at nmbu.no
Tue Oct 27 09:38:34 PDT 2015
Adding a soft link:
ln -s /usr/lib/x86_64-linux-gnu/libjpeg.la /usr/lib/libjpeg.la
allowed PostGIS to build, and postgis extensions to be
installed.
Håvard
On 22/10/2015 14:58:PM, Havard Tveite wrote:
> Hi,
> I am on Debian Wheezy (Debian 3.2.68-1+deb7u1) and get the following
> error message from "make" for PostGIS 2.2.0 with raster support
> (the default) against PostgreSQL 9.5beta1 (make is successful if I
> specify --without-raster):
> make[2]: Entering directory `....../postgis-2.2.0/raster/loader'
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I../rt_core -I../../liblwgeom -I/usr/local/include -I/usr/local/include -c raster2pgsql.c
> /bin/bash ../../libtool --mode=link gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I../rt_core -I../../liblwgeom -I/usr/local/include -I/usr/local/include ../rt_core/librtcore.a raster2pgsql.o ../../liblwgeom/liblwgeom.la -L/usr/local/lib -lgdal -L/usr/local/lib -lgeos_c -liconv -lm -o raster2pgsql
> libtool: error: cannot find the library '/usr/lib/libjpeg.la' or unhandled argument '/usr/lib/libjpeg.la'
> make[2]: *** [raster2pgsql] Error 1
> make[2]: Leaving directory `/home/havatv/src/postgis/postgis-2.2.0/raster/loader'
> make[1]: *** [rtloader] Error 2
> make[1]: Leaving directory `/home/havatv/src/postgis/postgis-2.2.0/raster'
> make: *** [all] Error 1
> my libjpeg.la is in /usr/lib/x86_64-linux-gnu/libjpeg.la
> postgis-2.2.0/libtool contains:
> sys_lib_search_path_spec="/usr/lib/gcc/x86_64-linux-gnu/4.7 /usr/lib/x86_64-linux-gnu /usr/lib /lib/x86_64-linux-gnu /lib "
> and
> sys_lib_dlsearch_path_spec="/lib /usr/lib /usr/lib/R/lib /usr/local/lib /home/license/arcgis/license10.0/bin /home/license/arcgis/license10.0/vmw/mw/lib-linux_optimized/ /usr/local/lib /opt/v8/lib /lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu /lib32 /usr/lib32 "
> gcc version 4.7.2 (Debian 4.7.2-5)
> I don't think there were any problems with 2.1.3 (against a
> PostgreSQL 9.1 that was compiled from sources). Here is the
> corresponding output from make for 2.1.3:
> make[2]: Entering directory `/home/havatv/src/postgis/postgis-2.1.3/raster/loader'
> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I../rt_core -I../../liblwgeom -I/usr/local/include -I/usr/local/include raster2pgsql.o -o .libs/raster2pgsql ../rt_core/librtcore.a ../../liblwgeom/.libs/liblwgeom.so -L/usr/local/lib /usr/local/lib/libgdal.so /usr/local/lib/libgeos_c.so /usr/local/lib/libiconv.so -lm
> make[2]: Leaving directory `/home/havatv/src/postgis/postgis-2.1.3/raster/loader'
> Regards,
> Håvard
