[postgis-users] How can I detect that geom != st_reverse(geom)	for linestrings?
    Paragon Corporation
    lr at pcorp.us
    Wed Sep  2 14:44:28 PDT 2015
Steve,
Forgot to mention -- there was  subtle bug in ST_OrderingEquals that prevented it from using a spatial index, which Vicky pointed out.  I fixed it for not yet released 2.1.9
https://trac.osgeo.org/postgis/ticket/3236
So sadly to be safe, you have to throw in an additional && if you need it to utilize spatial index.
-----Original Message-----
Sent: Wednesday, September 02, 2015 5:40 PM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Subject: RE: [postgis-users] How can I detect that geom != st_reverse(geom) for linestrings?
Have you tried
ST_OrderingEquals  ?
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
Sent: Wednesday, September 02, 2015 5:05 PM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] How can I detect that geom != st_reverse(geom) for linestrings?
Hi Bob,
Yes, for now I'm just taking a pgrouting path and reversing some of the edges so the coordinates flow correctly from end to end of the path. But it just dawned on me that I can change the test to geom::text = st_reverse(geom)::text and this will avoid the precision issue I was worded about.
It just seems like we should have a function that allows us to check for
sameness:
create or replace st_isSameGeometry(a geometry, b geometry) returns boolean language sql as $_$ select a::text=b::text; $_$;
-Steve
On 9/2/2015 4:37 PM, Basques, Bob (CI-StPaul) wrote:
> Hi Steve,
> I think you almost need to check every point from at least one
> linestring against the other linestring.
> You could check just one end, but they could still be the same but the
> other end different.  Also you could have line strings with the same
> end points, but different intermediate points.
> Your st_astext approach seems to be the most full proof, if it s just
> the direction that you are looking for, then you may need to do a
> double (or triple condition) pass if the line strings are congruent.
> You would need to check the ends against each other after finding out
> that they match up in physical space in order to get direction.
> bobb
>> On Sep 2, 2015, at 3:23 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com> wrote:
>> Hi all,
>> I just noticed that it is not obvious how to determine that geom and
>> st_reverse(geom) are different!
>> It seems that by definition st_equals(geom, st_reverse(geom)) is true
>> as is geom = st_reverse(geom). So this seems to be by definition, but
>> it brings up the question how to quickly and efficiently determine
>> that they are also different, even if they are "equal".
>> I'm doing st_astext(geom) != st_astext(st_reverse(geom)) but I worry
>> about precision issues doing this. I suppose I could also check if
>> the st_startpoint() of the two are the same, but that seems
>> problematic also.
>> Thoughts, -Steve _______________________________________________
>> postgis-users mailing list postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> _______________________________________________ postgis-users mailing
