[postgis-users] Install problem with PROJ directory
One
ohwang00 at gmail.com
Sun Sep 27 00:33:58 PDT 2015
I have a problem similar to the OP. I installed PostgreSQL and Proj4 on my
Mac, and now I want to install PostGIS from source. However, when I run the
./configure command, I get this result:
checking proj_api.h usability... no
checking proj_api.h presence... no
checking for proj_api.h... no
configure: error: could not find proj_api.h - you may need to specify the
directory of a PROJ.4 installation using --with-projdir
I believe that postgres and proj were installed correctly because sample
psql and proj commands appear to work okay.
If I do "which proj", I get this result:
/usr/local/bin/proj
Also, a search for "proj_api.h" shows these results, minus the file in the
source directory:
/Library/Frameworks/PROJ.framework/Versions/4/Headers/proj_api.h
/opt/local/include/proj_api.h
/usr/local/include/proj_api.h
I have tried the following and still failed to configure:
./configure --with-projdir=/usr/local/bin
./configure
--with-projdir=/Library/Frameworks/PROJ.framework/Versions/4/Headers/
./configure --with-projdir=/opt/local/include/
./configure --with-projdir=/usr/local/include
My specs:
-MacBookPro OS X Yosemite Version 10.10.2
-XCode version 6.3.2
-PostgreSQL version 9.3.5 , installed from source (I am using an older
version of Postgres because I need a version that's compatible with ArcGIS).
-Proj4 version 4.9.1 (the one at /usr/local/bin/proj is installed from
source, and the one at /opt/local is installed from MacPorts)
I am installing PostGIS from source, and not Homebrew, MacPorts, or
KyngChaos, because I need a version that will work with PostgreSQL 9.3.5.
What should I try next?
Thanks for your help.
Sample output:
$ ./configure
checking build system type... x86_64-apple-darwin14.1.0
checking host system type... x86_64-apple-darwin14.1.0
checking how to print strings... printf
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a sed that does not truncate output... /usr/bin/sed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc...
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld
checking if the linker
(/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld)
is GNU ld... no
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm
checking the name lister (/usr/bin/nm) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 196608
checking how to convert x86_64-apple-darwin14.1.0 file names to
x86_64-apple-darwin14.1.0 format... func_convert_file_noop
checking how to convert x86_64-apple-darwin14.1.0 file names to toolchain
checking for
option to reload object files... -r
checking for objdump... no
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... no
checking for strip... strip
checking for ranlib... ranlib
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking command to parse /usr/bin/nm output from gcc object... ok
checking for sysroot... no
checking for a working dd... /bin/dd
checking how to truncate binary pipes... /bin/dd bs=4096 count=1
checking for mt... no
checking if : is a manifest tool... no
checking for dsymutil... dsymutil
checking for nmedit... nmedit
checking for lipo... lipo
checking for otool... otool
checking for otool64... no
checking for -single_module linker flag... yes
checking for -exported_symbols_list linker flag... yes
checking for -force_load linker flag... yes
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... yes
checking for gcc option to produce PIC... -fno-common -DPIC
checking if gcc PIC flag -fno-common -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker
supports shared libraries... yes
checking dynamic linker characteristics... darwin14.1.0 dyld
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++...
is GNU ld... no
checking whether the g++ linker
checking for g++ option to produce PIC... -fno-common -DPIC
checking if g++ PIC flag -fno-common -DPIC works... yes
checking if g++ static flag -static works... no
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking for grep that handles long lines and -e... (cached) /usr/bin/grep
checking for ant... no
checking for cpp... /usr/bin/cpp
checking if g++ supports -Wall... yes
checking if g++ supports -Wmissing-prototypes... yes
checking if g++ supports -ffloat-store... no
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -ll
checking whether yytext is a pointer... yes
checking for bison... bison -y
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking for vasprintf... yes
checking for asprintf... yes
checking for _LARGEFILE_SOURCE value needed for large files... no
checking whether isfinite is declared... yes
checking for perl... /usr/bin/perl
checking for convert... no
configure: WARNING: ImageMagick does not seem to be installed. Documentation
cannot be built
checking for xsltproc... /usr/bin/xsltproc
checking for xmllint... /usr/bin/xmllint
checking for dblatex... no
configure: WARNING: dblatex is not installed so PDF documentation cannot be
built
configure: WARNING: could not locate Docbook stylesheets required to build
the documentation
checking CUnit/CUnit.h usability... no
checking CUnit/CUnit.h presence... no
checking for CUnit/CUnit.h... no
configure: WARNING: could not locate CUnit required for unit tests
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking for libiconv_open in -liconv... no
checking for iconv_open in -lc... no
checking for iconv_open in -liconv... yes
checking for iconvctl... no
checking for libiconvctl... no
checking for pg_config... /usr/local/pgsql/bin/pg_config
checking PostgreSQL version... PostgreSQL 9.3.5
checking libpq-fe.h usability... yes
checking libpq-fe.h presence... yes
checking for libpq-fe.h... yes
checking for PQserverVersion in -lpq... yes
checking for xml2-config... /usr/bin/xml2-config
checking libxml/tree.h usability... yes
checking libxml/tree.h presence... yes
checking for libxml/tree.h... yes
checking libxml/parser.h usability... yes
checking libxml/parser.h presence... yes
checking for libxml/parser.h... yes
checking libxml/xpath.h usability... yes
checking libxml/xpath.h presence... yes
checking for libxml/xpath.h... yes
checking libxml/xpathInternals.h usability... yes
checking libxml/xpathInternals.h presence... yes
checking for libxml/xpathInternals.h... yes
checking for xmlInitParser in -lxml2... yes
checking for geos-config... /usr/local/bin/geos-config
checking GEOS version... 3.4.2
checking geos_c.h usability... yes
checking geos_c.h presence... yes
checking for geos_c.h... yes
checking for initGEOS in -lgeos_c... yes
checking for sfcgal-config... /usr/local/bin/sfcgal-config
checking whether make sets $(MAKE)... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking for a thread-safe mkdir -p... ./install-sh -c -d
checking whether NLS is requested... yes
checking for msgfmt... /opt/local/bin/msgfmt
checking for gmsgfmt... /opt/local/bin/msgfmt
checking for xgettext... /opt/local/bin/xgettext
checking for msgmerge... /opt/local/bin/msgmerge
checking for ld used by GCC...
is GNU ld... no
checking for shared library run path origin... done
checking for CFPreferencesCopyAppValue... yes
checking for CFLocaleCopyCurrent... yes
checking for GNU gettext in libc... no
checking for iconv... yes
checking for working iconv... yes
checking how to link with libiconv... -liconv
checking for GNU gettext in libintl... no
checking whether to use NLS... no
Using user-specified proj directory:
Steps I followed to install Proj4 from source:
mkdir proj4
cd proj4
curl -O http://download.osgeo.org/proj/proj-4.9.1.tar.gz
gunzip proj-4.9.1.tar.gz
tar xf proj-4.9.1.tar
cd proj-4.9.1
./configure
make
make check
make install
View this message in context: http://postgis.17.x6.nabble.com/Install-problem-with-PROJ-directory-tp4998687p5008851.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
