[postgis-users] [Question] Point returned in ST_LineLocatePoint and ST_ClosestPoint is not able to detect in ST_Contains
Alexandre Neto
senhor.neto at gmail.com
Wed Sep 30 05:51:10 PDT 2015
The 0.00001 value is in your coordinate system units. From your example
it's probably degrees and not meters.
Alexandre Neto
Em qua, 30 de set de 2015 às 13:29, Dharshan Bharathur <
dharshan4help at gmail.com> escreveu:
> Thanks for the reply,
> Yes, I tried with ST_DWithin and it is working fine now.
> But then, according to doc "closest point on LineString to the given
> Point" is wrong statement right?
> And in "ST_DWithin(line,
> point, 0.00001)" , 0.000001 is in meter? what is the least /last value we
> can use?
> *Thanks & Regards*
> *Dharshan*
> On Wed, Sep 30, 2015 at 5:54 PM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> Unfortunately, due to the vagaries of the IEEE double precision grid,
>> your constructed point probably does not like *exactly* on your line,
>> but ever-so-slightly off. Try testing instead for ST_DWithin(line,
>> point, 0.00001) or something and it should work better.
>> P
>> On Tue, Sep 29, 2015 at 9:59 PM, Dharshan Bharathur
>> <dharshan4help at gmail.com> wrote:
>> > Hi all, Need experts advice.
>> > This is the same question I have asked here.
>> > I am using postgis's ST_LineLocatePoint to find out the closest point
>> on a
>> > LineString to the given Point, and using ST_LineInterpolatePoint to
>> extract
>> > a Point from the returned float number.(as referred here)
>> > This is my ST_LineLocatePoint Query
>> > SELECT ST_AsText(ST_LineInterpolatePoint(foo.the_line,
>> ST_LineLocatePoint(foo.the_line,ST_GeomFromText('POINT(12.962315
>> > 77.584841)')))) AS g FROM (SELECT
>> > ST_GeomFromText('LINESTRING(12.96145
>> > 77.58408,12.96219 77.58447,12.96302 77.58489,12.96316
>> > 77.58496,12.96348
>> > 77.58511)') AS the_line) AS foo;
>> > Output:
>> > g
>> > POINT(12.9624389808159 77.5845959902924)
>> > Which exactly lies on the linestring I have passed. Demonstration is
>> > displayed here.
>> > query with St_Closest function also returns the same points.
>> > But when I check whether this point lies in the same linestring using
>> > ST_Contains it always return false, even though the point lies within.
>> > My ST_Contains Query:
>> > SELECT ST_Contains(ST_GeomFromText('LINESTRING(12.96145
>> 77.58408,12.96219
>> > 77.58447,12.96302 77.58489, 12.96316 77.58496, 12.96348
>> > 77.58511)'),ST_GeomFromText('POINT(12.9624389808159
>> 77.5845959902924)'));
>> > Output:
>> > st_contains
>> > f
>> > I am not getting where I am doing wrong, why I am getting false. Can
>> anyone
>> > help me in this.
>> > I am using Postgresql : 9.4, postgis : 2.1
>> > Thanks & Regards
>> > Dharshan
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at lists.osgeo.org
>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150930/7c18c4b4/attachment.html>
