[postgis-users] Using SRID with meters, but still not getting UNITS in meters with ST_DWithin
Michael Moore
michaeljmoore at gmail.com
Mon Apr 11 11:21:06 PDT 2016
I am trying to find all zip codes withing a given range of current zip
code. For example, User is at zip code 95076 and want to know all zip codes
within a 30 mile range. This will always be a short distance, nothing over
50 miles. The source zip code is any place in the USA. My input table has
a latitude field, a longitude field and a POINT field for each zip code.
I want to supply in input in meters, not degrees. I do NOT want to cast to
*geography* because this prevents the index from being used.
Here is a *working query* that uses the index, but ST_DWithin is not
understanding ".05" as meters:
lcd1_dev=> select t2.city, t2.postalcode,
ST_Distance(t1.geo_position,t2.geo_position)
lcd1_dev-> from tpostalcoordinate t1
lcd1_dev-> left join tpostalcoordinate t2 on ST_DWithin(t1.*geo_position*
,t2.*geo_position* , .05)
lcd1_dev-> where t1.postalcode = '94404'and t1.countrycode2tcountry =
'US' and t2.countrycode2tcountry= 'US';
city | postalcode | st_distance
Redwood City | 94065 | 0.0273766323714193
San Mateo | 94408 | 0.00504738546179631
Belmont | 94002 | 0.0440065904155286
San Mateo | 94404 | 0
San Mateo | 94403 | 0.0370314731005901
San Mateo | 94407 | 0.0416118372581607
*This shows that I am using SRID 4896*
lcd1_dev=> select * from geometry_columns where f_table_name =
'tpostalcoordinate';
f_table_catalog | f_table_schema | f_table_name | f_geometry_column |
coord_dimension | srid | type
lcd1_dev | qsn_app | tpostalcoordinate | geo_position |
2 | 4896 | POINT
*4896 is UNIT "metre" as show here:*
4896 | EPSG | 4896 |
GEOCCS["ITRF2005",DATUM["International_Terrestrial_Reference_Frame_2005",SPHEROID["GRS
1980",6378137,298.257222101,AUTHORIT
Y["EPSG","7019"]],AUTHORITY["EPSG","6896"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],
UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Geocentric X",OTH
ER],AXIS["Geocentric Y",OTHER],AXIS["Geocentric
Z",NORTH],AUTHORITY["EPSG","4896"]] | +proj=geocent +ellps=GRS80 +units=m
+no_de
*The following (from EXPLAIN) proves that the index is being used in the
working query shown above:* -> Index Scan using tpostalcoordinate_pk on
tpostalcoordinate t1 (cost=0.42..8.45 rows=1 width=32)
What do I need to do to get this in meters without losing my index access?
TIA,
Mike
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160411/1204a36b/attachment.html>
