[postgis-users] Using SRID with meters, but still not getting UNITS in meters with ST_DWithin
Michael Moore
michaeljmoore at gmail.com
Mon Apr 11 12:37:45 PDT 2016
On Mon, Apr 11, 2016 at 12:31 PM, Michael Moore <michaeljmoore at gmail.com>
wrote:
> On Mon, Apr 11, 2016 at 11:50 AM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> Before I can even begin to address what's going on with the
>> index/query side, I have to ask about the coordinate system:
>> You are using a geocentric system for postal code points?
>> https://epsg.io/4896
>> This seems very odd indeed. If you were flying a satellite or drilling
>> a deep well, maybe you'd use geocentric coordinates, but simple postal
>> code queries? So, perhaps there's a core error to deal with first: why
>> are you in EPSG:4896?
>> P
>> On Mon, Apr 11, 2016 at 11:21 AM, Michael Moore <michaeljmoore at gmail.com>
>> wrote:
>> > I am trying to find all zip codes withing a given range of current zip
>> code.
>> > For example, User is at zip code 95076 and want to know all zip codes
>> within
>> > a 30 mile range. This will always be a short distance, nothing over 50
>> > miles. The source zip code is any place in the USA. My input table has
>> a
>> > latitude field, a longitude field and a POINT field for each zip code.
>> > I want to supply in input in meters, not degrees. I do NOT want to cast
>> to
>> > geography because this prevents the index from being used.
>> > Here is a working query that uses the index, but ST_DWithin is not
>> > understanding ".05" as meters:
>> > lcd1_dev=> select t2.city, t2.postalcode,
>> > ST_Distance(t1.geo_position,t2.geo_position)
>> > lcd1_dev-> from tpostalcoordinate t1
>> > lcd1_dev-> left join tpostalcoordinate t2 on
>> > ST_DWithin(t1.geo_position,t2.geo_position , .05)
>> > lcd1_dev-> where t1.postalcode = '94404'and t1.countrycode2tcountry =
>> 'US'
>> > and t2.countrycode2tcountry= 'US';
>> > city | postalcode | st_distance
>> > Redwood City | 94065 | 0.0273766323714193
>> > San Mateo | 94408 | 0.00504738546179631
>> > Belmont | 94002 | 0.0440065904155286
>> > San Mateo | 94404 | 0
>> > San Mateo | 94403 | 0.0370314731005901
>> > San Mateo | 94407 | 0.0416118372581607
>> > This shows that I am using SRID 4896
>> > lcd1_dev=> select * from geometry_columns where f_table_name =
>> > 'tpostalcoordinate';
>> > f_table_catalog | f_table_schema | f_table_name |
>> f_geometry_column |
>> > coord_dimension | srid | type
>> > lcd1_dev | qsn_app | tpostalcoordinate | geo_position
>> > 2 | 4896 | POINT
>> > 4896 is UNIT "metre" as show here:
>> > 4896 | EPSG | 4896 |
>> GEOCCS["ITRF2005",DATUM["International_Terrestrial_Reference_Frame_2005",SPHEROID["GRS
>> > 1980",6378137,298.257222101,AUTHORIT
>> Y["EPSG","7019"]],AUTHORITY["EPSG","6896"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Geocentric
>> > X",OTH
>> > ER],AXIS["Geocentric Y",OTHER],AXIS["Geocentric
>> > Z",NORTH],AUTHORITY["EPSG","4896"]] | +proj=geocent +ellps=GRS80
>> +units=m
>> > +no_de
>> > The following (from EXPLAIN) proves that the index is being used in the
>> > working query shown above:
>> > -> Index Scan using tpostalcoordinate_pk on tpostalcoordinate t1
>> > (cost=0.42..8.45 rows=1 width=32)
>> > What do I need to do to get this in meters without losing my index
>> access?
>> > TIA,
>> > Mike
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/postgis-users
> Here is what we do to create the column on the table:
> 1. SELECT AddGeometryColumn('qsn_app','tpostalcoordinate',
> 'geo_position',4326,'POINT',2);
> 2. UPDATE tpostalcoordinate pc set pc.geo_position =
> ST_SetSRID(ST_Point(pc.longitude, pc.latitude), 4326);
> 3. CREATE INDEX tpostal_geo_position_idx ON tpostalcoordinate USING
> gist(geo_position);
> I am on EPSG:4896 because I tried about 10 others that were also meters
> and that's just the one I ended up on . There is one thing you said that
> leads me to believe there is something I don't understand: "...geocentric
> system...". My understanding is that there are two datatypes to choose
> from ; geometry and geography. I have chosen geometry because 1. it should
> be faster due to simpler calculations and 2. It should be faster because it
> can use the index. Beyond that I thought that I would then need to choose
> a proper SRID. The two criteria for choosing an SRID for me are 1. the
> units are meters and 2. it is based on a datum that is appropriate for the
> USA. Now the fact that you said: "geocentric system" makes me think that
> maybe there is something else I need to be looking at when choosing a
> proper SRID. A little more on the application: The user wants to know all
> of the schools that are within a specific distance of his current location,
> his zip code. Precision is not important. We get the user's zip code from
> the screen and we have a list of schools and their zip codes.
> Thanks,
> Mike
John,
The latitude and longitude are correct and I know that because if I cast my
geometry points to geography, every thing works perfectly: it understand
meters and expected target zip codes are in the result set. The only
problem with with casting to geography is that geography does not use the
index.
Regards,
Mike
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160411/a0fa51b7/attachment.html>
