[postgis-users] attempt to redefine parameter "postgis.backend"
Armand Turpel
armand.turpel.mnhn at gmail.com
Tue Apr 12 02:32:24 PDT 2016
I have a wired problem after upgrading from pg 9.1 postgis 1.5 to pg
9.3 postgis 2.2.1
On some tables with a geometry column the error appear:
*attempt to redefine parameter "postgis.backend"
*even if a query dosent contains the geometry column.
On other tables which have a geometry column too the problem dosent
appear. May some geometry columns are corrupted.
I guess i have done some thing wrong with the pg/postgis upgrade. The
mess is done. Since the last upgrade, 2 weeks, the database is in
production. I cant easily restore the old database.
Is there a way to fix this problem?
Thanks for helping,
atu
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160412/1b505e88/attachment.html>
