[postgis-users] Using SRID with meters, but still not getting UNITS in meters with ST_DWithin
Lee Hachadoorian Lee.Hachadoorian+L at gmail.com
Tue Apr 12 09:26:55 PDT 2016
Michael,
There are many ways to accomplish this, and the most efficient approach is
going to depend on what else you are using this data for. If literally the
*only* thing you are using the geometries for is to calculate distances
between postal zones, I would consider creating a table like:
CREATE TABLE postal_zone_distance (
  source_zone text,
  dest_zone text,
  distance_m double precision,
  PRIMARY KEY (source_zone, dest_zone)
and populating it *once* with distances between all postal codes in the US,
so that you can run future queries using an attribute select (WHERE
distance_m < 50000) instead of a spatial select. Rerun whenever postal
zones change, which shouldn't be all that often. You can populate it with
something like:
INSERT INTO postal_zone_distance
SELECT a.postalcode, b.postalcode, ST_Distance(a.geo_position::geography,
b.geo_position::geography)
FROM tpostalcoordinate a CROSS JOIN tpostalcoordinate b;
Will take a while to run, but future queries will be faster.
If you intend to use this for more than just these distances, there are
several options, all of which are valid, but again it depends what you want
to use it for. The main issue between using Paul's suggestion to just
define columns as geography vs keeping in geometry is whether you might
visualize the postal zones using a GIS. If you will be using QGIS or ArcGIS
to connect to PostGIS to map the zones, you will need to keep in geometry.
In this case you can, as Lucas suggest, define a functional index on the
geography cast, while keeping the underlying data in geometry.
Some other notes:
* To get to your original question about units of measurement, while
lat-long SRIDs (like 4326) say the units are "meters", ST_Distance and
other distance and area functions always just work in Cartesian
coordinates, meaning they treat long and lat as X and Y in a Cartesian plan
and they take parameters and return answers in degrees, which isn't really
meaningful. There are special functions like ST_Distance_Spheroid which
take lat-long geometry and return distance in meters on the spheroid. And
ST_Distance on geography type also returns meters.
* Be careful about your choice of SRID. The fact that you tried to
transform (or assign?) this to EPSG 4896 is a red flag because because one
shouldn't just "try" SRIDs. Your data come to you in an SRID, and you
should only transform it for a particular purpose. In fact you should make
sure that you know the datum of your original lat-long geometries.
Considering that the data are for the US, it is quite possible that your
data are in EPSG 4269 (lat-long North American Datum 1983, used for much US
government data including by the Census Bureau), rather than being EPSG
4326 (World Geodetic System 1984, the datum used by GPS satellites).
I highly recommend Obe & Hsu's PostGIS in Action (
https://www.manning.com/books/postgis-in-action-second-edition), esp. Ch 3
on Spatial Reference System Considerations.
Best,
--Lee
Lee Hachadoorian
Assistant Professor of Instruction, Geography & Urban Studies
Assistant Director, Professional Science Master's in GIS
Temple University
On Mon, Apr 11, 2016 at 11:00 PM, Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Go back to basics, use a geography column from the start:
> ALTER TABLE tpostalcoordinate ADD COLUMN geog geography(point, 4326);
> UPDATE tpostalcoordinate SET geog =
> geography(ST_SetSRID(ST_MakePoint(longitude, latitude), 4326));
> CREATE INDEX tpostalcoordinate_gix ON tpostalcoordinate USING GIST (geog);
> SELECT a.*
>   ON ST_DWithin(a.geog, b.geog, 10000)
>   WHERE
>     a.countrycode2tcountry = 'US' AND
>     b.countrycode2tcountry = 'US' AND
>     b.postalcode = '94404';
> A geocentric system is one where every point is referenced relative to
> the center of the earth, so they all have an x,y,z. It's not something
> you want to use.
> P
> On Mon, Apr 11, 2016 at 12:31 PM, Michael Moore <michaeljmoore at gmail.com>
> wrote:
> > On Mon, Apr 11, 2016 at 11:50 AM, Paul Ramsey <pramsey at cleverelephant.ca
> > wrote:
> >> Before I can even begin to address what's going on with the
> >> index/query side, I have to ask about the coordinate system:
> >> You are using a geocentric system for postal code points?
> >> https://epsg.io/4896
> >> This seems very odd indeed. If you were flying a satellite or drilling
> >> a deep well, maybe you'd use geocentric coordinates, but simple postal
> >> code queries? So, perhaps there's a core error to deal with first: why
> >> are you in EPSG:4896?
> >> P
> >> On Mon, Apr 11, 2016 at 11:21 AM, Michael Moore <
> >> wrote:
> >> > I am trying to find all zip codes withing a given range of current zip
> >> > code.
> >> > For example, User is at zip code 95076 and want to know all zip codes
> >> > within
> >> > a 30 mile range. This will always be a short distance, nothing over 50
> >> > miles. The source zip code is any place in the USA.  My input table
> has
> >> > a
> >> > latitude field, a longitude field and a POINT field for each zip code.
> >> > I want to supply in input in meters, not degrees. I do NOT want to
> cast
> >> > to
> >> > geography because this prevents the index from being used.
> >> > Here is a working query that uses the index, but ST_DWithin  is not
> >> > understanding ".05" as meters:
> >> > lcd1_dev=>   select t2.city, t2.postalcode,
> >> > ST_Distance(t1.geo_position,t2.geo_position)
> >> > lcd1_dev->   from      tpostalcoordinate t1
> >> > lcd1_dev->   left join tpostalcoordinate t2 on
> >> > ST_DWithin(t1.geo_position,t2.geo_position , .05)
> >> > lcd1_dev->   where t1.postalcode = '94404'and t1.countrycode2tcountry
> >> > 'US'
> >> > and t2.countrycode2tcountry= 'US';
> >> >      city     | postalcode |     st_distance
> >> >  Redwood City | 94065      |  0.0273766323714193
> >> >  San Mateo    | 94408      | 0.00504738546179631
> >> >  Belmont      | 94002      |  0.0440065904155286
> >> >  San Mateo    | 94404      |                   0
> >> >  San Mateo    | 94403      |  0.0370314731005901
> >> >  San Mateo    | 94407      |  0.0416118372581607
> >> > This shows that I am using SRID 4896
> >> > lcd1_dev=> select * from geometry_columns where f_table_name =
> >> > 'tpostalcoordinate';
> >> >  f_table_catalog | f_table_schema |   f_table_name    |
> >> > f_geometry_column |
> >> > coord_dimension | srid | type
> >> >  lcd1_dev        | qsn_app        | tpostalcoordinate | geo_position
> >> > 2 | 4896 | POINT
> >> > 4896 is UNIT "metre" as show here:
> >> >  4896 | EPSG      |      4896 |
> GEOCCS["ITRF2005",DATUM["International_Terrestrial_Reference_Frame_2005",SPHEROID["GRS
> >> > 1980",6378137,298.257222101,AUTHORIT
> Y["EPSG","7019"]],AUTHORITY["EPSG","6896"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Geocentric
> >> > X",OTH
> >> > ER],AXIS["Geocentric Y",OTHER],AXIS["Geocentric
> >> > Z",NORTH],AUTHORITY["EPSG","4896"]] | +proj=geocent +ellps=GRS80
> >> > +units=m
> >> > +no_de
> >> > The following (from EXPLAIN) proves that the index is being used in
> the
> >> > working query shown above:
> >> >    ->  Index Scan using tpostalcoordinate_pk on tpostalcoordinate t1
> >> > (cost=0.42..8.45 rows=1 width=32)
> >> > What do I need to do to get this in meters without losing my index
> >> > access?
> >> > TIA,
> >> > Mike
> >> > _______________________________________________
> >> > postgis-users mailing list
> >> > postgis-users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/postgis-users
> > Here is what we do to create the column on the table:
> > 1.    SELECT AddGeometryColumn('qsn_app','tpostalcoordinate',
> > 'geo_position',4326,'POINT',2);
> > 2.    UPDATE tpostalcoordinate pc set pc.geo_position =
> > ST_SetSRID(ST_Point(pc.longitude, pc.latitude), 4326);
> > 3.    CREATE INDEX tpostal_geo_position_idx ON tpostalcoordinate USING
> > gist(geo_position);
> > I am on EPSG:4896 because I tried about 10 others that were also meters
> and
> > that's just the one I ended up on .  There is one thing you said that
> leads
> > me to believe there is something I don't understand: "...geocentric
> > system...". My understanding is that there are two datatypes to choose
> from
> > ; geometry and geography. I have chosen geometry because 1. it should be
> > faster due to simpler calculations and 2. It should be faster because it
> can
> > use the index.  Beyond that I thought that I would then need to choose a
> > proper SRID. The two criteria for choosing an SRID for me are 1. the
> units
> > are meters and 2. it is based on a datum that is appropriate for the USA.
> > Now the fact that you said: "geocentric system" makes me think that maybe
> > there is something else I need to be looking at when choosing a proper
> SRID.
> > A little more on the application: The user wants to know all of the
> schools
> > that are within a specific distance of his current location, his zip
> code.
> > Precision is not important. We get the user's zip code from the screen
> and
> > we have a list of schools and their zip codes.
> > Thanks,
> > Mike
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160412/935bb1fb/attachment.html>
