[postgis-users] Using SRID with meters, but still not getting UNITS in meters with ST_DWithin
Michael Moore
michaeljmoore at gmail.com
Tue Apr 12 16:45:56 PDT 2016
Okay, let's see if I finally get this. The reason I need to start with SRID
4326 is because the Coordinate system has an Axes of latitude and longitude
and I only have latitude and longitude to start with. My starting latitude
and longitude were based on the WSG84 Datum. looking at Coordinate system
for https://epsg.io/4326. 4326 is also based on WSG84, so it's a match.
Unfortunately for me, 4326 is ellipsoidal and as such
the Unit is degrees. So in order do do my calculations in meters, I need to
"translate" my point onto a flat map. 2163 represents such a map as as
would be expected with a flat map, the unit is in meters.
Also there is the little issue of the "covered area" that needs to be taken
into consideration but I understand that.
Thanks!
Mike
On Tue, Apr 12, 2016 at 12:50 PM, Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> This:
> "while lat-long SRIDs (like 4326) say the units are "meters""
> is not correct. Long-lat SRS's pretty clearly state their units are
> degrees. More to the point, the units are evaluated in a spherical
> context, not a planar one, so applying planar calculations to them
> will yield junk answers. You want to apply planar calculations to
> planar coordinates, and spherical calculations to spherical
> coordinates.
> This is why we have the geometry (planar) and geography (spherical)
> bifurcation.
> In my previous email I gave you a recipe to run your problem in
> geography (spherical) space. Since you've sort of indicated that your
> data are USA only, I'll also give you a planar (geometry) recipe,
> using a suitable planar projection for the USA.
> We will use the USA National Atlas Albers projection
> (https://epsg.io/2163) for this example. It won't provide meter-level
> accuracy over such a wide area, but presumable for something as coarse
> as a "postal codes in radius" query, that won't matter.
> ALTER TABLE tpostalcoordinate ADD COLUMN geom geometry(point, 2136);
> UPDATE tpostalcoordinate SET geom =
> ST_Transform(ST_SetSRID(ST_MakePoint(longitude, latitude), 4326),2163);
> CREATE INDEX tpostalcoordinate_geom_ix ON tpostalcoordinate USING GIST
> (geom);
> SELECT a.*
> FROM tpostalcoordinate a
> JOIN tpostalcoordinate b
> ON ST_DWithin(a.geom, b.geom, 10000)
> WHERE
> a.countrycode2tcountry = 'US' AND
> b.countrycode2tcountry = 'US' AND
> b.postalcode = '94404';
> Note the differences with the geography approach:
> - use use the geometry type, and we populate the column with data
> transformed into our working planar projection
> - then we're free to just use ST_DWithin(geom, geom, radius) and
> everything magically works fine.
> ATB,
> P
> On Tue, Apr 12, 2016 at 12:40 PM, Michael Moore <michaeljmoore at gmail.com>
> wrote:
> > Lee, Paul,
> > Thanks so much for your time.
> > Lee,
> > My understanding is that there are about 42,000 zips in the US, So a
> cross
> > join should result in about 1.7 Billion entries into the
> > postal_zone_distance table. Maybe that's not so bad, I'll have to run the
> > numbers. Where as this might be the fastest possible solution, it's
> probably
> > over-kill for my meager needs. I understand what you mean by needing to
> know
> > first the SRID of the Latitude and Longitude from my source table. It
> means
> > very little without knowing the Datum from which they were derived.
> Thanks
> > to some youtube videos I think I grasp this.
> > You said:
> >> ...while lat-long SRIDs (like 4326) say the units are "meters",
> >> ST_Distance and other distance and area functions always just work in
> >> Cartesian coordinates, meaning they treat long and lat as X and Y in a
> >> Cartesian plan and they take parameters and return answers in degrees,
> which
> >> isn't really meaningful.
> > I believe you and my experience seems to confirm it, however I can't
> seem
> > to reconcile this with the documentation for ST_Distance which says ...
> > http://postgis.net/docs/ST_DWithin.html
> >> For Geometries: The distance is specified in units defined by the
> spatial
> >> reference system of the geometries. For this function to make sense, the
> >> source geometries must both be of the same coordinate projection,
> having the
> >> same SRID.
> > Is the documentation wrong??? or am I just not interpreting it correctly.
> > If it IS wrong, for god sake I hope they fix it as I have now just wasted
> > too much of everybody's time on and issue that could have been cleared
> up by
> > better documentation.
> > Again, thanks to everybody who replied, you are most generous.
> > Regards,
> > Mike
> > On Tue, Apr 12, 2016 at 9:26 AM, Lee Hachadoorian
> > <Lee.Hachadoorian+L at gmail.com> wrote:
> >> Michael,
> >> There are many ways to accomplish this, and the most efficient approach
> is
> >> going to depend on what else you are using this data for. If literally
> the
> >> *only* thing you are using the geometries for is to calculate distances
> >> between postal zones, I would consider creating a table like:
> >> CREATE TABLE postal_zone_distance (
> >> source_zone text,
> >> dest_zone text,
> >> distance_m double precision,
> >> PRIMARY KEY (source_zone, dest_zone)
> >> and populating it *once* with distances between all postal codes in the
> >> US, so that you can run future queries using an attribute select (WHERE
> >> distance_m < 50000) instead of a spatial select. Rerun whenever postal
> zones
> >> change, which shouldn't be all that often. You can populate it with
> >> something like:
> >> INSERT INTO postal_zone_distance
> >> SELECT a.postalcode, b.postalcode,
> ST_Distance(a.geo_position::geography,
> >> b.geo_position::geography)
> >> FROM tpostalcoordinate a CROSS JOIN tpostalcoordinate b;
> >> Will take a while to run, but future queries will be faster.
> >> If you intend to use this for more than just these distances, there are
> >> several options, all of which are valid, but again it depends what you
> want
> >> to use it for. The main issue between using Paul's suggestion to just
> define
> >> columns as geography vs keeping in geometry is whether you might
> visualize
> >> the postal zones using a GIS. If you will be using QGIS or ArcGIS to
> connect
> >> to PostGIS to map the zones, you will need to keep in geometry. In this
> case
> >> you can, as Lucas suggest, define a functional index on the geography
> cast,
> >> while keeping the underlying data in geometry.
> >> Some other notes:
> >> * To get to your original question about units of measurement, while
> >> lat-long SRIDs (like 4326) say the units are "meters", ST_Distance and
> other
> >> distance and area functions always just work in Cartesian coordinates,
> >> meaning they treat long and lat as X and Y in a Cartesian plan and they
> take
> >> parameters and return answers in degrees, which isn't really meaningful.
> >> There are special functions like ST_Distance_Spheroid which take
> lat-long
> >> geometry and return distance in meters on the spheroid. And ST_Distance
> on
> >> geography type also returns meters.
> >> * Be careful about your choice of SRID. The fact that you tried to
> >> transform (or assign?) this to EPSG 4896 is a red flag because because
> one
> >> shouldn't just "try" SRIDs. Your data come to you in an SRID, and you
> should
> >> only transform it for a particular purpose. In fact you should make sure
> >> that you know the datum of your original lat-long geometries.
> Considering
> >> that the data are for the US, it is quite possible that your data are in
> >> EPSG 4269 (lat-long North American Datum 1983, used for much US
> government
> >> data including by the Census Bureau), rather than being EPSG 4326 (World
> >> Geodetic System 1984, the datum used by GPS satellites).
> >> I highly recommend Obe & Hsu's PostGIS in Action
> >> (https://www.manning.com/books/postgis-in-action-second-edition), esp.
> Ch 3
> >> on Spatial Reference System Considerations.
> >> Best,
> >> --Lee
> >> Lee Hachadoorian
> >> Assistant Professor of Instruction, Geography & Urban Studies
> >> Assistant Director, Professional Science Master's in GIS
> >> Temple University
> >> On Mon, Apr 11, 2016 at 11:00 PM, Paul Ramsey <
> >> wrote:
> >>> Go back to basics, use a geography column from the start:
> >>> ALTER TABLE tpostalcoordinate ADD COLUMN geog geography(point, 4326);
> >>> UPDATE tpostalcoordinate SET geog =
> >>> geography(ST_SetSRID(ST_MakePoint(longitude, latitude), 4326));
> >>> CREATE INDEX tpostalcoordinate_gix ON tpostalcoordinate USING GIST
> >>> (geog);
> >>> SELECT a.*
> >>> ON ST_DWithin(a.geog, b.geog, 10000)
> >>> WHERE
> >>> A geocentric system is one where every point is referenced relative to
> >>> the center of the earth, so they all have an x,y,z. It's not something
> >>> you want to use.
> >>> P
> >>> On Mon, Apr 11, 2016 at 12:31 PM, Michael Moore <
> >>> wrote:
> >>> > On Mon, Apr 11, 2016 at 11:50 AM, Paul Ramsey
> >>> > wrote:
> >>> >> Before I can even begin to address what's going on with the
> >>> >> index/query side, I have to ask about the coordinate system:
> >>> >> You are using a geocentric system for postal code points?
> >>> >> https://epsg.io/4896
> >>> >> This seems very odd indeed. If you were flying a satellite or
> drilling
> >>> >> a deep well, maybe you'd use geocentric coordinates, but simple
> postal
> >>> >> code queries? So, perhaps there's a core error to deal with first:
> why
> >>> >> are you in EPSG:4896?
> >>> >> P
> >>> >> On Mon, Apr 11, 2016 at 11:21 AM, Michael Moore
> >>> >> wrote:
> >>> >> > I am trying to find all zip codes withing a given range of current
> >>> >> > zip
> >>> >> > code.
> >>> >> > For example, User is at zip code 95076 and want to know all zip
> >>> >> > codes
> >>> >> > within
> >>> >> > a 30 mile range. This will always be a short distance, nothing
> over
> >>> >> > 50
> >>> >> > miles. The source zip code is any place in the USA. My input
> table
> >>> >> > has
> >>> >> > a
> >>> >> > latitude field, a longitude field and a POINT field for each zip
> >>> >> > code.
> >>> >> > I want to supply in input in meters, not degrees. I do NOT want to
> >>> >> > cast
> >>> >> > to
> >>> >> > geography because this prevents the index from being used.
> >>> >> > Here is a working query that uses the index, but ST_DWithin is
> not
> >>> >> > understanding ".05" as meters:
> >>> >> > lcd1_dev=> select t2.city, t2.postalcode,
> >>> >> > ST_Distance(t1.geo_position,t2.geo_position)
> >>> >> > lcd1_dev-> from tpostalcoordinate t1
> >>> >> > lcd1_dev-> left join tpostalcoordinate t2 on
> >>> >> > ST_DWithin(t1.geo_position,t2.geo_position , .05)
> >>> >> > lcd1_dev-> where t1.postalcode = '94404'and
> >>> >> > t1.countrycode2tcountry =
> >>> >> > 'US'
> >>> >> > and t2.countrycode2tcountry= 'US';
> >>> >> > city | postalcode | st_distance
> >>> >> > Redwood City | 94065 | 0.0273766323714193
> >>> >> > San Mateo | 94408 | 0.00504738546179631
> >>> >> > Belmont | 94002 | 0.0440065904155286
> >>> >> > San Mateo | 94404 | 0
> >>> >> > San Mateo | 94403 | 0.0370314731005901
> >>> >> > San Mateo | 94407 | 0.0416118372581607
> >>> >> > This shows that I am using SRID 4896
> >>> >> > lcd1_dev=> select * from geometry_columns where f_table_name =
> >>> >> > 'tpostalcoordinate';
> >>> >> > f_table_catalog | f_table_schema | f_table_name |
> >>> >> > f_geometry_column |
> >>> >> > coord_dimension | srid | type
> >>> >> > lcd1_dev | qsn_app | tpostalcoordinate |
> geo_position
> >>> >> > 2 | 4896 | POINT
> >>> >> > 4896 is UNIT "metre" as show here:
> >>> >> > 4896 | EPSG | 4896 |
> GEOCCS["ITRF2005",DATUM["International_Terrestrial_Reference_Frame_2005",SPHEROID["GRS
> >>> >> > 1980",6378137,298.257222101,AUTHORIT
> Y["EPSG","7019"]],AUTHORITY["EPSG","6896"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Geocentric
> >>> >> > X",OTH
> >>> >> > ER],AXIS["Geocentric Y",OTHER],AXIS["Geocentric
> >>> >> > Z",NORTH],AUTHORITY["EPSG","4896"]] | +proj=geocent +ellps=GRS80
> >>> >> > +units=m
> >>> >> > +no_de
> >>> >> > The following (from EXPLAIN) proves that the index is being used
> in
> >>> >> > the
> >>> >> > working query shown above:
> >>> >> > -> Index Scan using tpostalcoordinate_pk on tpostalcoordinate
> t1
> >>> >> > (cost=0.42..8.45 rows=1 width=32)
> >>> >> > What do I need to do to get this in meters without losing my index
> >>> >> > access?
> >>> >> > TIA,
> >>> >> > Mike
> >>> >> > _______________________________________________
> >>> >> > postgis-users mailing list
> >>> >> > postgis-users at lists.osgeo.org
> >>> >> > http://lists.osgeo.org/mailman/listinfo/postgis-users
> >>> > Here is what we do to create the column on the table:
> >>> > 1. SELECT AddGeometryColumn('qsn_app','tpostalcoordinate',
> >>> > 'geo_position',4326,'POINT',2);
> >>> > 2. UPDATE tpostalcoordinate pc set pc.geo_position =
> >>> > ST_SetSRID(ST_Point(pc.longitude, pc.latitude), 4326);
> >>> > 3. CREATE INDEX tpostal_geo_position_idx ON tpostalcoordinate
> USING
> >>> > gist(geo_position);
> >>> > I am on EPSG:4896 because I tried about 10 others that were also
> meters
> >>> > and
> >>> > that's just the one I ended up on . There is one thing you said that
> >>> > leads
> >>> > me to believe there is something I don't understand: "...geocentric
> >>> > system...". My understanding is that there are two datatypes to
> choose
> >>> > from
> >>> > ; geometry and geography. I have chosen geometry because 1. it should
> >>> > be
> >>> > faster due to simpler calculations and 2. It should be faster because
> >>> > it can
> >>> > use the index. Beyond that I thought that I would then need to
> choose
> >>> > a
> >>> > proper SRID. The two criteria for choosing an SRID for me are 1. the
> >>> > units
> >>> > are meters and 2. it is based on a datum that is appropriate for the
> >>> > USA.
> >>> > Now the fact that you said: "geocentric system" makes me think that
> >>> > maybe
> >>> > there is something else I need to be looking at when choosing a
> proper
> >>> > SRID.
> >>> > A little more on the application: The user wants to know all of the
> >>> > schools
> >>> > that are within a specific distance of his current location, his zip
> >>> > code.
> >>> > Precision is not important. We get the user's zip code from the
> screen
> >>> > and
> >>> > we have a list of schools and their zip codes.
> >>> > Thanks,
> >>> > Mike
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160412/0166e725/attachment.html>
