[postgis-users] attempt to redefine parameter "postgis.backend"
Armand Turpel armand.turpel.mnhn at gmail.com
Wed Apr 13 02:35:07 PDT 2016
Hi Paul,
Here the result:
"$libdir/postgis-2.2"
"$libdir/postgis-2.1"
"$libdir/rtpostgis-2.2"
Armand
On 12/04/2016 17:50, Paul Ramsey wrote:
> What does this query return?
> select distinct probin from pg_proc where probin like '%postgis%';
> On Tue, Apr 12, 2016 at 2:32 AM, Armand Turpel
> <armand.turpel.mnhn at gmail.com> wrote:
>> Hi,
>> I have a wired problem after upgrading from pg 9.1  postgis 1.5 to pg 9.3
>> postgis 2.2.1
>> On some tables with a geometry column the error appear:
>> even if a query dosent contains the geometry column.
>> On other tables which have a geometry column too the problem dosent appear.
>> May some geometry columns are corrupted.
>> I guess i have done some thing wrong with the pg/postgis upgrade. The mess
>> is done. Since the last upgrade, 2 weeks, the database is in production. I
>> cant easily restore the old database.
>> Is there a way to fix this problem?
>> Thanks for helping,
>> atu
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/postgis-users
