[postgis-users] st_createoverview
    Horst Düster
    horst.duester at sourcepole.ch
    Thu Apr 14 01:39:53 PDT 2016
Thanks for your response.
I created a workflow how to reproduce the mentioned behaviour:
1. Upload the image clean_tiled.tif to my DB with:
raster2pgsql -t auto -I -f rast clean_tiled.tif | pgsql .....
(Upload file clean_tiled.sql is attached)
2. Create overviews for levels 2,4,8,16,32 with
select st_createoverview('clean_tiled'::regclass, 'rast'::name, 2) etc.
3. Load DB raster to QGIS with DB manager or have a look at [1] to get
the result.
> It could be a bug. A few things to check:
> Is the input already tiled?
Yes, the base layer is tiled. Data source extent 1089x1093 pixel and
tile size is 33x39
> Would it work if you made the input untiled ?
when I use the input untiled it works fine.
> Are all input tiles of the same size ?
Yes all input tiles have the same size 33x39
> Are the input tiles sizes multiple of the given reduction factor ?
The input tiles sizes are nearly the multiple: 33x28
[1] http://qgiscloud.com/hdus1/st_createoverview
All the best
Horst
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
Dr. Horst Düster
Managing Director
Sourcepole AG - Linux & Open Source Solutions
Weberstrasse 5, 8004 Zürich, Switzerland
Tel: +41 (0)44 440 77 11
Direkt: +41 (0)44 515 67 70
horst.duester at sourcepole.ch  http://www.sourcepole.ch
www.sourcepole.ch/kurse - Das Kursangebot Frühling 2016
Type: application/x-bzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160414/1c30bd4c/attachment.bin>
