[postgis-users] PostGIS Deprecated Functions
Sandro Santilli strk at keybit.net
Wed Apr 20 07:19:31 PDT 2016
On Wed, Apr 20, 2016 at 07:06:15AM -0700, Victor Rodriguez wrote:
> Thanks!  Would you say it is important to track down these uses of
> deprecated functions or would you say it's not that important?
Deprecated function will be removed after a couple of releases
from deprecation. Use of each of those would trigger a WARNING
message with details about when it was deprecated.
Other than the WARNING, those function continue to work as they
did, as long as they are available.
You could just gather those WARNINGs from the postgresql logs
and act on those.
--strk;
