[postgis-users] Borked PostGIS 2.2 Upgrade
Paul Ramsey pramsey at cleverelephant.ca
Thu Aug 11 07:42:42 PDT 2016
Your SE question inspired me to write up a post which has some remedies in
the final section
http://blog.cleverelephant.ca/2016/08/postgis-upgrade.html
P
On Wed, Aug 10, 2016 at 9:08 PM, Lee Hachadoorian <
Lee.Hachadoorian+L at gmail.com> wrote:
> Running PostGIS on PostgreSQL 9.3 Linux Mint 17.2 using
> ubuntugis-unstable PPA. I had a working PostGIS 2.1.4. I recently apt
> upgraded to PostGIS 2.2.2. I then tried:
>     ALTER EXTENSION postgis UPDATE TO "2.2.2";
> However this resulted in:
>     ERROR:  could not access file "$libdir/postgis-2.2": No such file
> or directory
> I posted about this to GIS.SE
> (http://gis.stackexchange.com/questions/206412/how-can-i-do-
> a-soft-upgrade-from-postgis-2-1-4-to-2-2-2).
> Paul Ramsey responded and helped me figure out that something went
> wrong with upgrade. (Thanks Paul!) At this point, I need to figure out
> whether I can salvage the installation. I wanted to avoid dump and
> restore, but at this point even dump is not working because of
> nonworking PostGIS. I'm moving this to postgis-users as the
> back-and-forth is more appropriate to a ML than GIS.SE
> I'm running into dependency issues. I was *not* able to downgrade
> because PostGIS 2.1 depends on GDAL 1.x, and I have already upgraded
> to GDAL 2.0. When I looked to see what would be involved in
> downgrading GDAL, apt wants to uninstall QGIS 2.16 and a bunch of
> other stuff.
> I apt uninstalled PostGIS 2.2 and reinstalled PostGIS 2.2. That
> database still thinks it's on PostGIS 2.1, which is missing, and
> CREATE EXTENSION fails (no control file) and ALTER EXTENSION fails as
> previously.
> Best,
> --Lee
> Lee Hachadoorian
> Asst Professor of Geography, Dartmouth College
> http://geospatial.commons.gc.cuny.edu/
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160811/bc30da7a/attachment.html>
