[postgis-users] issue loading shapefiles into postgis via batch
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Fri Aug 26 10:27:25 PDT 2016
There are several ways to do this. One of the easiest (and most
insecure) is to set the PGPASSWORD environment variable with the
password for "postgres" user in the script before the psql command.
Regards
Bo Victor Thomsen
AestasGIS
Denmark
Den 26/08/16 kl. 15:59 skrev Mark Volz:
> Hello,
> I am having issues with a Windows batch load script. This script
> should scan for any new shapefiles in the “PostGIS Incoming” folder,
> load the shapefiles into postGIS, then place the shapefiles in a
> completed folder. This script seemed to work in the past, but is now
> complaining about a password – which I did not change.
> What is wrong with this script, and or what can I do to specify a
> password?
> # LOAD SHAPEFILES INTO POSTGIS SCRIPT
> set PATH=C:\Program Files\PostgreSQL\9.2\bin;%PATH%
> cd /d "D:\PostGISIncoming\LyonGIS"
> rem load data to postgis
> for %%f in (*.shp) do shp2pgsql -d -I -s 103749 -W LATIN1 %%f %%~nf |
> psql -w -U postgres -d lyongis
> rem move data to done folder
> for %%a in (*.*) do move "%%a" "D:\PostGISIncoming\LyonGIS\Done"
> Thanks
> Sincerely,
> *Mark Volz, GISP***
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160826/3ddced55/attachment.html>
