[postgis-users] PostGIS export - data is inexplicably truncated from 3234 records to 3221 when using 'pgsql2shp', PGAdmin, AND QGIS 2.6+
Ben Madin
ben at ausvet.com.au
Sun Dec 4 20:50:24 PST 2016
FWIW, if you are running
SELECT gid, st_isValid(geom) FROM data;
you might want to try
SELECT gid, st_isValid(geom), st_isValidReason(geom) FROM data;
As someone that gets a lot of rubbish data, st_isvalidreason() is my # 1 favourite function…
cheers
Ben
> On 2016-12-05, at 00:06 , Regina Obe <lr at pcorp.us> wrote:
> Ruth,
> Following up on Jorge's answer. I do recall we have some logic with the import and export routines that refuse to import or export invalid geometries.
> I think the policy has changed over the years and you're running a fairly old install.
> I forget what the condition is, but I know we spent a lot of time discussing it.
> So the one you have below that has a geometry, can you check
> ST_IsValid(geom) on the geometry you have below? If it returns false, then as Jorge mentioned that's the problem. You could try fixing with ST_MakeValid.
> SELECT gid, iso3, last_updat, area_km, name, ST_IsValid(geom)
> FROM as_clean_test_ogr_export_utf8
> where name = 'Oakland';
> --- Ruth's email --
> Does anyone know If there are NULL geoms in a table (any table - such as the one created by this shapefile) will it invalidate geometry that was valid and present?
> Reason I ask is I see missing geometries in my shapefile exports that WERE present in the original shapefile and the PostGIS import. However on export they disappear.
> Below is a feature I cannot seem to export to shapefile when I try to round-trip this table...It has geom in PostGIS...however it 'disappears' and cannot be viewed in QGIS on export.
> Ex:
> SELECT gid, iso3, last_updat, area_km, name, geom
> 3228;"USA";"2016-11-10";0;"Oakland";"0106000020E61000000100000001030000000100000008000000C3F5285C8FEA54C08104C58F3137454032E6AE25E4EB54C03108AC1C5A64454032E6AE25E4EB54C00F0BB5A6796F4540F0164850FCDC54C0E3C798BB9670454066F7E461A1C654C0B6847CD0B3714540F7065F984CC554C029ED0DBE3039454017D9CEF753E3 (...)"
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Jorge Gustavo Rocha
> Sent: Saturday, December 03, 2016 2:25 PM
> To: Ruth Simm <goldfish_and_muskie at yahoo.com>; PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] PostGIS export - data is inexplicably truncated from 3234 records to 3221 when using 'pgsql2shp', PGAdmin, AND QGIS 2.6+
> Hi Ruth,
> I've imported your data from shp to postgis, with ogr2ogr, like this:
> ogr2ogr -overwrite -f "PostgreSQL" PG:"host=localhost user=geobox dbname=geotuga password=geobox" -a_srs EPSG:4326 -nlt MULTIPOLYGON -nln usa as_clean_test_ogr_export_utf8.shp
> Then, I run the following query:
> select count(*), st_isvalid(wkb_geometry) from usa group by st_isvalid(wkb_geometry);
> The results is:
> count | st_isvalid
> 13 |
> 3218 | t
> 3 | f
> So, I would say that you have invalid geometries that are causing this problem.
> I hope it helps.
> Regards,
> Jorge
> s 18:44 de 03-12-2016, Ruth Simm escreveu:
>> Hi,
>> I'm having a serious data export problem with the PGAdmin widget and
>> pgsql2shp (QGIS too). The problem lies within converting a PostGIS
>> table to shapefile. *I put in 3234 feature counts...and I get back
>> 3221.*
>> I get limited information from the error reports (see below...QGIS
>> gives me the most information...but it is minimal). The errors (when
>> available) reference ogr....but not much else. Ironically, the only
>> way I've found to actually export the *full* record set is by using ogr2ogr.
>> I'm not sure why round-tripping with the PGAdmin tool is failing so bad.
>> It seems to be able to import the initial 3234 - but cannot export the
>> full set.
>> I do notice the Polygon/Multipolygon converting happening...but seeing
>> that many of the tables "Multipolygons" are just single Polygons added
>> into the Multipolygon bucket...I'm not sure if that has anything to do
>> with it.
>> Very perplexed. If anybody can pull my dataset and repo this (or tell
>> me how they got around it - using anything BUT ogr2ogr) I'd appreciate it!!!!
>> Here are my specs:
>> PostgreSQL 9.2.4 (on a Linux server)
>> pgsql2shp 2.1.1
>> PostGIS 2.0 Shapefile and DBF Loader Exporter (PGAdmin tool) QGIS
>> 2.6.0 - Brighton (on windows...we've tested using more up-to-date
>> versions too)
>> Here is the data <https://spaces.hightail.com/space/ihoE7> (2 MB
>> unzipped on a cloud drive).
>> Here is what I do...
>> 1) Load the shapefile into Postgres using the PGAdmin tool (works
>> fine...notably it is loaded as a MULTIPOLYGON[2] EVEN THOUGH the
>> Shapefile type is Polygon)
>> *3234 record counts*
>> Importing with configuration: as_clean_test_ogr_export_utf8, public,
>> geom, H:\as_clean_test_ogr_export_utf8.shp, mode=c, dump=1, simple=0,
>> geography=0, index=1, shape=1, srid=4326 Shapefile type: Polygon
>> PostGIS type: MULTIPOLYGON[2] Shapefile import completed.
>> Connecting: host=pgsqlgis-repos port=5432 user=local-dev
>> password='*********'
>> 2) Try to export the table tp shapefile... (this doesn't work for the
>> following..and notably they are all trying to export it as a Polygon)
>> UPON Export (using >pgsql2shp)
>> H:\>pgsql2shp -f E:/as_clean_test_ogr_export_utf8.shp -h <hostname> -u
>> <username> -p <port> -P <password> <postgrestable>
>> "as_clean_test_ogr_export_utf8"
>> Initializing...
>> Done (postgis major version: 2).
>> Output shape: Polygon
>> Dumping: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX*[3221 rows]*.
>> QGIS (Save As in QGIS 2.6.0)
>> Export to vector file failed.
>> Error: Feature write errors:
>> Feature geometry not imported (OGR error: ) Feature geometry not
>> imported (OGR error: ) Feature geometry not imported (OGR error: )
>> Feature geometry not imported (OGR error: ) *Only 3221 of 3234
>> features written.*
>> Export Using PostGIS 2.0 Shapefile and DBF Loader Exporter
>> *3221 record counts*
>> Exporting with configuration: as_clean_test_ogr_export_utf8, public,
>> Table export completed.
>> postgis-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/postgis-users
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Inform tica
> Universidade do Minho
> 4710-057 Braga
> Tel: +351 253604480
> Fax: +351 253604471
> M vel: +351 910333888
> skype: nabocudnosor
Ben Madin
m : +61 448 887 220 t : +61 8 9336 5022
e : ben at ausvet.com.au
10 High Street, Fremantle
Western Australia
find us: http://w3w.co/duke.basket.decks
on the web: www.ausvet.com.au
This transmission is for the intended addressee only and is confidential information. If you have received this transmission in error, please delete it and notify the sender. The contents of this email are the opinion of the writer only and are not endorsed by Ausvet unless expressly stated otherwise. Although Ausvet uses virus scanning software we do not accept liability for viruses or similar in any attachments. Thanks for reading.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161205/4491e790/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161205/4491e790/attachment.png>
