[postgis-users] Topology: error creating aggregated topogeom (at city level) from a neighborhoods topogeom
Sandro Santilli strk at keybit.net
Mon Feb 1 07:04:45 PST 2016
On Mon, Feb 01, 2016 at 11:03:14AM -0200, Lucas Ferreira Mation wrote:
> >Here you're trying to pass a "layer_id" as the "type" of component for a non-hierarchical layer, thus the error
> *TopoElementArray_Agg(ARRAY[(tg_geom_dump_utm).id,(tg_geom_dump_utm).layer_id])*
> works.
Yes, that's how you're supposed to use it.
> What is not very clear from the syntax is if the syntax of
> should follow the child or the parent topogeom "class" (hierarquical or not)
It's TopoElement that matters, TopoElementArray_Agg is just an
aggregate to collect a set of TopoElement objects.
TopoElement is documented here:
http://postgis.net/docs/manual-2.2/topoelement.html
"second element represents layer identifier of the child TopoGeometry"
> To recap, this is the code that works:
Consider adding it to the PostGIS Wiki !
This may be a good starting point:
http://trac.osgeo.org/postgis/wiki/UsersWikiCreatingTopoGeometryObjects
--strk;
