[postgis-users] Tiger geocoder - error instead of null when unlocatable
Regina Obe
lr at pcorp.us
Mon Feb 8 10:17:39 PST 2016
Matthew,
Now that you mention it I have run into the same issue myself especially
since county is such a common table name.
Go ahead and enter a ticket to request schema qualifying. It has been
something I've been thinking of doing anyway.
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Matthew Syphus
Sent: Monday, February 08, 2016 1:09 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Tiger geocoder - error instead of null when
unlocatable
Regina,
Thank you for looking into this. Before entering a bug I did some other
checks and believe I've found the cause.
The function in question creates a query without schema-qualified table
names.
ERROR: column co.statefp does not exist
LINE 2: ...cefp = p.placefp) LEFT JOIN county co ON ('25' = co.statefp...
CONTEXT: PL/pgSQL function geocode_address(norm_addy,integer,geometry) line
383 at FOR over EXECUTE statement
PL/pgSQL function geocode(norm_addy,integer,geometry) line 14 at FOR over
SELECT rows
PL/pgSQL function geocode(character varying,integer,geometry) line 26 at
RETURN QUERY
I have a county table in another schema (also in the search path). After
renaming that other table it appeared to work. In fact, it returned
locations (not just null) where it errored out before, meaning it isn't just
unlocatable addresses; it is affecting all output. Also, it looks like the
table names in the tiger and tiger_data schemas are not obscure (a good
thing) and therefore may be in use somewhere else in a database (a bad
thing).
Can the extension be updated so the generated scripts and all functions
always use schema-qualified table names? I realize that might be a tall
order, but it seems very easy for table names to collide within the search
path. Should I still enter this as a bug?
Thanks for the excellent work on geocoding (and PostGIS); the address
standardizing, data import, and geocode results are impressive.
Matthew
Of Regina Obe
Sent: Sunday, February 07, 2016 8:45 AM
To: 'PostGIS Users Discussion'
unlocatable
Matthew,
Can you ticket this one in our ticket tracker - http://postgis.net/support/
Unfortunately I don't have Idaho data loaded in my instance and can't
trigger the problem with the data I have just by replacing the state.
It does sound like a bug though if other addresses work. I'll try to take a
look at it next week while I'm looking at other tiger issues.
Thanks,
Regina
http://www.postgis.us
http://postgis.net
Of Matthew Syphus
Sent: Sunday, February 07, 2016 12:43 AM
<mailto:postgis-users at lists.osgeo.org> >
unlocatable
Apologies for not including version details originally.
"postgis_full_version"
"POSTGIS="2.2.1 r14555" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.7.6"
LIBJSON="0.11" TOPOLOGY RASTER"
PostgreSQL 9.5.0
CentOS 6.5
mst
Of Matthew Syphus
Sent: Saturday, February 06, 2016 9:06 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Tiger geocoder - error instead of null when
unlocatable
After following the instructions (several times) and apparently successfully
installing tiger geocoder and the tiger data for Idaho, I keep getting an
error when the geocoder can't find an address.
With a locatable address it works just fine.
SELECT * FROM geocode('3300 state st, boise, id 83703')
When an address is not locatable, I assume it should return null (and move
on to the next in the batch).
Instead, it returns an error:
SELECT * FROM geocode('3300 state st, neverland, id 9876543210')
LINE 2: ...cefp = p.placefp) LEFT JOIN county co ON ('16' = co.statefp...
QUERY: SELECT DISTINCT ON
(sub.predirabrv,sub.fename,COALESCE(sub.suftypabrv, sub.pretypabrv)
,sub.sufdirabrv,coalesce(p.name,zip.city,cs.name,co.name),s.stusps,sub.zip)
sub.predirabrv as fedirp, sub.fename, COALESCE(sub.suftypabrv,
sub.pretypabrv) as fetype, sub.sufdirabrv as fedirs,
coalesce(p.name,zip.city,cs.name,co.name)::varchar as place, s.stusps as
state, sub.zip as zip, interpolate_from_address($1, sub.fromhn, .
It doesn't seem to matter which address element causes the problem, the
error is the same and it kills the query. Is there some error handling that
is getting missed? The examples I've seen look like it just returns null.
Thank you for any help.
mst
_____
This email has been scanned for spam and viruses by Proofpoint Essentials
cloud email security - click here
<https://us1.proofpointessentials.com/index01.php?mod_id=11&mod_option=logit
em&mail_id=Z07c%2BrvT0fHg&rid=6780640&report=1> to report this email as
spam.
_____
em&mail_id=fwStnh5A4b6W&rid=6780640&report=1> to report this email as spam.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160208/1845530b/attachment.html>
