[postgis-users] Hobbyist question about curves
h hdixon at bigpond.net.au
Fri Feb 12 15:21:49 PST 2016
I use PostGIS and QGIS on an OpenSUSE machine with a fairly light level
of expertise.
I am interested in roads, and would like to be able to see / examine
curves / bends.
I have downloaded roads from OSM  (nodes and ways), brought these into
PostGIS as CSV files and am able to display them in
QGIS.St_LinetoCurve(lineGeom)
What I would like to do is convert these lines into curves.  I have
tried using "St_LinetoCurve(lineGeom)" to form the curves, but the
geometry returned appears identical to the original lines.
My main assumption is that if I pass St_LinetoCurve a line string,
it will return a multigeometry object containing lines and circular
arcs.
How can I convert a line string into a collection of lines and circular
arcs?
Also, once this is done, is there a command to return the radius of the
circular arcs created?
Many thanks
hdixon
