[postgis-users] st_clusterwithin fails
Ronnie Lassche ronnie.lassche at merkator.info
Wed Feb 17 04:44:54 PST 2016
I’m trying to use the new st_clusterwithin function, but it keeps failing.
I’ve tried to cluster 20 points with the following query.
SELECT
                ST_ClusterWithin(geom, 50)
FROM winkels
Most of the times I get the message
“ERROR: Tolerance not defined
SQL state: XX000”
A few times it did work and gave me a result, but trying again will lead to
the same error.
I’m working with postgis 2.2.2dev (but also tried it with 2.2.0).
Anyone has a solution how to solve this?
*Ronnie Lassche*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160217/37ef2f36/attachment.html>
