[postgis-users] Excessive null records after shapefile import
Dave McCann drmccann at progressivepartnering.com
Thu Feb 25 12:34:59 PST 2016
I'm using the pgAdmin Shapefile import manager plugin.
I dropped the table and ran the import again and did't get the extra rows.
Not sure what the issue was. Could have been something machine related.
It's a virtual test machine.
Dave McCann
Progressive Partnering Inc.
Ph: 615.469.2529
On Thu, Feb 25, 2016 at 1:52 PM, Dheeraj Chand <dheeraj at dheerajchand.com>
wrote:
> No, it’s not.  Can you show the command that you’re using to import, the
> means by which you’re verifying the duplication, etc.?
> On Feb 25, 2016, at 12:55 PM, Dave McCann <
> drmccann at progressivepartnering.com> wrote:
> I've noticed that after importing a shapefile into PostGIS that it's
> creating twice as many records as were in the shapefile and the fields are
> all NULL in the extra records.
> Is that normal?
> PostGIS 2.1 PgSQL 9.5
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160225/9efd19b0/attachment.html>
