[postgis-users] questions/issues when creating a topology
Lucas Ferreira Mation
lucasmation at gmail.com
Mon Jan 25 07:26:35 PST 2016
Sandro,
tks very much for the answers. After week to parse and try to implement
your sugestions I think we made good progress. Of of the 316k polygons, we
get 308 polygons that were not included.
Bellow are some follow-up questions (in line bellow).
> Message: 1
> Date: Sun, 17 Jan 2016 14:23:25 +0100
> From: Sandro Santilli <strk at keybit.net>
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] questions/issues when creating a topology
> Message-ID: <20160117132325.GA8245 at localhost>
> Content-Type: text/plain; charset=us-ascii
> On Thu, Jan 14, 2016 at 09:57:48AM -0200, Lucas Ferreira Mation wrote:
> > 1) What is the role of ST_Force2D() function in
> > toTopoGeom(ST_Force2D(geom),...) ? The code fails if I omit this
> function.
> > However my data is already 2D.
> ST_Force2D should make no difference when the input is already 2D.
> If it does there's a bug hiding somewhere and you're welcome to
> file a ticket about it (with a way to reproduce).
I actually managed to run most test cases without the ST_Force2D()
function. The only case it did make a difference was when creating a
topology with the original SRID (4674 , SIRGAS 2000) and no tolerance
parameter. With the ST_Force2D() wrapipng the input polygons, the loop
runs. Without it, there is a crash in the database (connection lost with
database).
> > 2) In most test I did, I got an error when uploading one or two polygons
> > (out of a 900 polygons in Acre state). How can I add these afterward?
> > Assume all the edges that define those error-polygons have already been
> > added. How do I define a new face by those edges and attribute that to
> the
> > topogeom for these error-polygons?
> > Let's say polygon A can be defined by edges 1, 2, 3 and 4, which are
> > already in the topology when other polygons were inserted. How do I
> define
> > face A and attribute that to the topogeom?
> Faces are automatically defined. You associate attributes with
> TopoGeometry objects, which you can define in your case by specifying
> the faces making up the polygon.
> See http://postgis.net/docs/manual-dev/CreateTopoGeom.html
Ok, got it to work. To document for others. Fist I used QGIS to know the
original polygon - face pairs. This is done manually, by overlaying
serveral layers (orginal polygons, topgeom, face bounding boxes). For
example, from the atached image, I learnt that I should associate the
polygon cod_setor=290390405000036 with face_id=13314 of the corresponding
topology. This, this fixes the "hole" in the topology for that polygon
UPDATE temp_geom_bahia2 SET tg_geom_dump_utm = '(28,1,13314,3)' WHERE
cod_setor = '290390405000036'
You may also try to re-run toTopoGeom on the previously failed
> polygons. Sometimes the function works when finding a different
> starting state.
This worked for 50 aditional cases of of the 358 errors (on the test with
UTM reprojected polygons and with tolerance parameter of 1m).
I'll now try to increase the tolerance parameter (to say 2m, 5m, 10m) to
see if the remaining polygons get added to the topology.
> > 3) Is there a way to manually edit topologies, in QGIS for instance? I'm
> > thinking of a workflow for repairing a map. After doing the automatic
> fixes
> > in Postgis and creating a topology, someone wants to manually correct
> some
> > feature. For instance, move an edge or a point, while maintaining the
> > topological properties. Is there a QGIS plugin for that?
> https://plugins.qgis.org/plugins/pgtopoeditor/
I see cool options to remove find dangling edges, remove edges and points
and find Orpaned topogeoms. But supose I wanto to change the shape of an
edge, by mooving a few vertices among it's path in QGIS, while preserving
the nodes where it intersects with other edges. Is it possible to do that
(and preserve the topological properties)? What about moving nodes? Can
pgtopoeditor manage that?
> > 4) Is not including a tolerance parameter in to... equivalent to a zero
> > tolerance?
> Yes. This is something that might be good to change in the future
> but for now it is the same.
> > 5) Does topology behaves differently depending on whether the SRID is in
> > decimal degrees or meters? Ideally, I would prefer to have the tolerance
> > parameter in meters, as it is a more intuitive unit and have a constant
> > amount of "snapping" across the areas. However that means choosing a
> > specific UTM zone for reprojecting each state. However states in Brasil
> are
> > quite large, spanning more then one UTM zone. Even Acre, the small state
> I
> > used for testing spans two UTM zones
> Topology makes no intepretation of projections.
> Coordinates are always considered to be cartesian.
> > 6) I tested creating topologies with the original Sirgas 2000 decimal
> > degree spatial reference (srid 4674, a decimal degree system, quite
> similar
> > to wgs84 but slightly more optimized for Brasil) and also with a
> > reprojection to a UTM zone (srid 32719), which is where most of the
> > polygons are located. The errors are not the same.
> When you pass no (or 0) tolerance, one is computed automatically based
> on the minimum drift detectable by a "double precision" number.
> Using lat/lon units usually means numbers closer to the 0 thus having
> a smaller minimum tolerance. This changes overall results.
> > 7) Has there been any progress on some sort of index for topogeometries,
> so
> > spatial queries can run faster? (I found this 2013 tread
> http://osgeo-org.1560.x6.nabble.com/spatial-index-for-topology-td5085935.html
> >on
> > the topic, but nothing more recent). Of course one can always cast to
> > geometry (topogeom::geometry) and index that, but that is duplicating the
> > information somewhat.
> No progress. A TopoGeometry object is externally defined so cannot really
> be indexed on itself. The geometry cast is volatile for this reason,
> and cannot be used in an index.
> What you could do is change the select queries to filter on bounding
> box of components. It would be a pretty complex query as it'd have to
> step by the "relation" table and the "layer" table to finally get
> to the real data, which si already indexed.
> Or you could build a cache of bounding boxes, automatically updating
> it whenever the primitives in the topology are updated, and use that
> column as a filter.
this is interesting idea. Any example on this?
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> Subject: Digest Footer
> postgis-users mailing list
> http://lists.osgeo.org/mailman/listinfo/postgis-users
> End of postgis-users Digest, Vol 167, Issue 10
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160125/00882757/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160125/00882757/attachment.png>
