[postgis-users] Error on a raster table restore
David Haynes
haynesd2 at gmail.com
Thu Jan 28 10:08:48 PST 2016
The problem is with pg_restore for raster tables not in the public schema
use this url for reference. https://trac.osgeo.org/postgis/ticket/2485#no1
This is a fix I have implemented that seems to work, I might have all of
the raster_constraint functions though...
SHOW search_path'
Alter the following functions to include the pg_catalog in the search path.
Alter Function _raster_constraint_nodata_values (raster) SET
Search_path="$user", pg_catalog,public;
Alter Function _raster_constraint_out_db (raster) SET Search_path="$user",
pg_catalog,public;
Alter Function _raster_constraint_pixel_types(raster) SET
Alter Function _overview_constraint(raster, integer, name, name, name) SET
now try restore command
On Wed, Jan 20, 2016 at 10:35 AM, Cedric Duprez <Cedric.Duprez at ign.fr>
wrote:
> Yes, the function ST_BandMetadata, with the right parameters, is in my
> public functions list.
> Both full versions of postgis and postgresql are the same.
> Le 15/01/2016 10:21, Tom van Tilburg a écrit :
> Just checking the obvious:
> Is there a function ST_BandMetedata in your functions list?
> And what is the full version output of the original server?
> On Fri, 15 Jan 2016 at 10:03 Cedric Duprez < <Cedric.Duprez at ign.fr>
> Cedric.Duprez at ign.fr> wrote:
>> Hi Tom,
>> Thanks for your answer.
>> I am sure that rasters are enabled in my postgis dbase (the first thing
>> I checked). Raster functions are in the public schema.
>> This is the result of SELECT postgis_full_version() :
>> POSTGIS="2.1.0 r11822" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
>> March 2012" GDAL="GDAL 1.11.0, released 2014/04/16" LIBXML="2.9.1"
>> LIBJSON="UNKNOWN" TOPOLOGY RASTER
>> Cedric
>> Le 15/01/2016 09:09, Tom van Tilburg a écrit :
>> > Cedric,
>> > Are you sure rasters are enabled in your new postgis dbase? Please
>> > check for the existence of raster functions (st_bandmetadata in
>> > particular) in public.functions and run SELECT postgis_full_version()
>> > Tom
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/postgis-users
> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160128/6a222d94/attachment.html>
