[postgis-users] tiger geocoder address normalization issue (bug?)
James Marca
jmarca at translab.its.uci.edu
Thu Jan 28 13:39:53 PST 2016
My goal is to use the address standarizer to match streets from two
different data sources.
Test case is 8th Street in Alameda CA
I was reading through the docs and found standardize_address
(http://postgis.net/docs/standardize_address.html), along with two
different ways to invoke it...using the us_[lex,gaz,rules] and the
tiger.pagc[lex,gaz,rules].
I think I found an issue of sorts.
First, using the 'us_' variant, all is well. If I query with Eighth
Street or 8th Street, I expect the street name to be the same so I can
match them, and they are:
hpms_geocode=# SELECT name,suftype FROM standardize_address('us_lex', 'us_gaz', 'us_rules', '1 8th St, Alameda, CA');
name | suftype
8 | STREET
(1 row)
hpms_geocode=# SELECT name,suftype FROM standardize_address('tiger.pagc_lex','tiger.pagc_gaz', 'tiger.pagc_rules' , '1 8th St, Alameda, CA');
name | suftype
8 | ST
(1 row)
However, if I do the same with the tiger.pagc variant, the results do
not match:
name | suftype
8 | ST
(1 row)
hpms_geocode=# SELECT name,suftype FROM standardize_address('tiger.pagc_lex','tiger.pagc_gaz', 'tiger.pagc_rules' , '1 Eighth St, Alameda, CA');
name | suftype
8TH | ST
(1 row)
Obviously I will just use the 'us_' version, but if the 'tiger.pagc_'
version is maintained, I think this is a bug and should be fixed
Regards,
James
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160128/534496b7/attachment.sig>
