[postgis-users] Fwd: GEOMfromEWKB missing
Tom van Tilburg
tom.van.tilburg at gmail.com
Sat Jan 30 12:45:44 PST 2016
Hi Das,
I had to look three times to your email to notice the tricky difference
between *LWGEOMFromWKB and *geomfromewkb() (notice the extra 'e'?)
Seems you're trying to import an dump from an older version of postgis
(1.5?) into a newer 2.2 version. There will be a lot more problems than
only these messages like that.
Please follow these instructions on doing a hard-upgrade (or upgrade the
hard way ;-)
http://www.postgis.org/docs/postgis_installation.html#hard_upgrade
Best,
Tom
On Thu, 21 Jan 2016 at 15:44 Dasaraden MAUREE <dasaraden.mauree at gmail.com>
wrote:
> Subject: GEOMfromEWKB missing
> I am quite new to psql and I am trying to carry on a work that has been
> started by someone else and I am trying to import an sql dump he made, and
> I am having the following errors:
> *psql:nameofdatabase.sql:3847: ERROR: could not find function
> "LWGEOMFromWKB" in file "/usr/lib/postgresql/9.3/lib/postgis-2.2.so
> <http://postgis-2.2.so>" psql:nameofdatabase.sql:3850: ERROR: function
> postgis.geomfromewkb(bytea) does not exist*
> It seems to me from the \df command that the geomfromewkb() function is
> here but is in the public schema. This should not be a problem then for
> psql to find it right, since when I do
> SHOW search_path;
> public,$user,data,tiger
> are here.
> Once I will be able to import the DB, I want to run a Java script to
> extract some info. from there.
> One of the errors I get is:
> *org.postgresql.util.PSQLException: ERROR: function
> st_contains(postgis.geometry, postgis.geometry) does not exist Hint: No
> function matches the given name and argument types. You might need to add
> explicit type casts.*
> I don't understand again why I have these errors when these functions
> seems to be present in the DB.
> Does anyone know about these and can tell me how I can fix this?
> Thanks,
> Das
> Dasaraden MAUREE
> Docteur de l'Université de Strasbourg
> Post-Doctoral Research Fellow
> Ecole Polytechnique Fédérale de Lausanne
> Laboratoire d'Energie Solaire et de Physique du Bâtiment
> LE 1 103 (Bâtiment LE)
> Station 18
> CH - 1015 Lausanne
> Suisse
> +41 21 693 55 56
> @D_Mauree
> [image: https://sites.google.com/site/dasaradenmauree/]
> <https://sites.google.com/site/dasaradenmauree/>
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160130/5cc0a2e0/attachment.html>
