[postgis-users] GRANTable Row Permissions
James Keener
jim at jimkeener.com
Fri Jul 1 22:50:40 PDT 2016
I'm trying to work out how to grant permissions to rows in a table
without having to rebuild the pg auth mechanisms (see below). One option
is to have many tables (each representing a row), and grant normally.
The other is, like I build below, uses a table and a recursive CTE to
resolve the PG group membership and apply it to the table in question
using a RLS policy. Is any of this sane?
So, aay I have
create table viz (
viz_id bigserial primary key,
name text
create role group_a;
create role group_b;
create role user1;
create role user2;
create role user3;
grant group_a to user1;
grant group_b to group_a;
insert into viz (name) values ('test 1'),('test 2'),('test 3');
I am trying to find a way to essentially do the following:
revoke select on viz from public;
grant select on viz to group_a where viz_id = 1;
grant select on viz to user2 where viz_id = 2;
grant select on viz to group_b where viz_id = 3;
With RLS I can create a policy that can validate via an arbitrary sql
statement, but I can't think of a clean way to have row-level grants
that can be implemented without having to kludge the pg permission
system into a table. The following kind of gets at what I want, but
uses a table instead of being able to grant.
create table viz_perm (
viz_id bigint references viz,
role_name text,
can_view boolean not null default false
alter table viz enable row level security;
alter table viz_perm enable row level security;
create policy viz_permissions on viz_perm for select using (
(with recursive rec_roles(grantee,granted) as (
select roless.rolname as grantee, groupss.rolname as granted
from pg_roles roless
inner join pg_auth_members
on roless.oid = pg_auth_members.member
inner join pg_roles groupss
on groupss.oid = pg_auth_members.roleid
union
select rec_roles.grantee as grantee, groupss.rolname as granted
from rec_roles
inner join pg_roles roless on roless.rolname = rec_roles.granted
select bool_or(true)
from rec_roles
where
role_name = current_user
or (grantee = current_user and granted = role_name))
create policy viz_permissions on viz using (
(select bool_or(can_view)
from viz_perm
where viz_perm.viz_id=viz.viz_id)
insert into viz_perm (viz_id, role_name, can_view) values
(1, 'group_a', true),
(2, 'user2', true),
(3, 'group_b', true);
grant select on viz to user1;
grant select on viz_perm to user1;
grant select on viz to user2;
grant select on viz_perm to user2;
set role user1;
select * from viz;
-- viz_id | name
-- 1 | test 1
-- 3 | test 3
--(2 rows)
reset role;
set role user2;
select * from viz;
-- viz_id | name
-- 2 | test 2
--(1 row)
reset role;
While the above more-or-less works, it feels very wonky. Is there a
better way to do this? Would it be better to have a table for each viz,
necessitating each table having a single row, and using the standard
permission system. Is what I describe and build in this email an
acceptable way to go about doing what I want to do?
Thanks,
Jim
