[postgis-users] Incorrect Result for ST_CountAgg with nodata pixels?
Michael Treglia
mtreglia at gmail.com
Tue Jul 12 13:56:04 PDT 2016
Hi All,
I'm working to do some overlay analyses between raster and vector layers,
and having an issue getting an accurate count of pixels per polygon.
My query is below - basically my raster layer has values ranging 1-5, with
some nodata pixels (defined as such, with values of 0). I want to
calculate, for each polygon, the proportion of pixels, of the total
(including nodata), with values of 1 and 2.
The first ST_CountAgg statement (yielding 'count_undevel') seems to be
working as expected, and reports an accurate number. However, the second
one, to create the 'count_total' field consistently gives an over-count.
Any guess as to what might be going on/how to correct? I'll gladly share
the properties of the data if that would be useful.
Thanks!
Mike
SELECT *,
count_undevel/(count_total)::float as PropVeg --Calculates proportion of
pixels within each building that are class 1 or 2 based on count_undevel
and count_total
INTO resultsvectorlayers.pctgrn
FROM(
SELECT
p.*,
--Count number of pixels per building with values 1 or 2
ST_CountAgg(
ST_Reclass(
ST_Clip(rast, p.geom_2263),
1,'[1-2]:1, [3-5]:0', '8BUI',0), 1,TRUE) --reclassifies classes 1 and 2 as
1, reclassifies values 3-5 as 0, and designates 0 as nodata
as count_undevel,
--Count total number of pixels
ST_CountAgg(
1,FALSE)
as count_total
FROM staging.naip_ndvi_classified_2013 r, staging.nycbldgs p
WHERE ST_INTERSECTS(r.rast, p.geom_2263) --and rid = 2
group by p.geom_2263, p.gid
) AS FOO;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160712/9aa9cd14/attachment.html>
