[postgis-users] Raster tile size impact results
Pierre Bails
bails at getredbird.com
Mon Jul 18 03:23:06 PDT 2016
Thank you for the tips.
Well, I don't know why, but the st_clip function doesn't seem work fine.
After clipping and dumping each pixel as point, some points follow tiles,
others follow the geometry. Any idea why ?
For now, to avoid the problem, I apply a St_ContainsProperly after the dump.
[image: pasted1]
Red : geometry
Light blue : tiles
Dark blue : pixels as points
Thank you for your help !
Pierre
Pierre Bails
GIS Engineer
*Redbird*
EMEA - 16, rue de la Comète - 75007 Paris - France
US - 44 Tehama St, San Francisco, CA 94105 - USA
Mobile: +33 677 375 851 | US Office: +1 415 366 0191 | FR Office: +33 184
165 201
bails at getredbird.com | www.getredbird.com | Facebook
<https://www.facebook.com/redbird.drones> | Twitter
<https://twitter.com/redbirdHQ> | Youtube
<https://www.youtube.com/channel/UC9ab5NnNorfVcRdynbTzSLw/videos>
Le ven. 15 juil. 2016 à 17:28, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
a écrit :
> Sorry for the late answer.
> You have to vectorize them on the fly from within OpenJump:
> SELECT (ST_DumpAsPolygons(rast).* FROM yourrastertable;
> If your raster is very big and tiled, just vectorize the tiles you need:
> SELECT rid, rast::geometry FROM yourrastertable;
> Look at the rids and then:
> WHERE rid = x or rid = y
> Pierre
> > -----Original Message-----
> > From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> Behalf
> > Of Pierre Bails
> > Sent: Friday, June 24, 2016 12:32 PM
> > To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> > Subject: Re: [postgis-users] Raster tile size impact results
> > Hello,
> > Unfortunatly, I don't find a way to print raster results in OpenJump.
> Can you
> > explain me how I can do it ?
> > Pierre
> > Le lun. 20 juin 2016 à 16:16, Pierre Racine <Pierre.Racine at sbf.ulaval.ca
> > <mailto:Pierre.Racine at sbf.ulaval.ca> > a écrit :
> > I would try to understand, visually using OpenJump, how your tiles
> are
> > clipped in the two cases... I guess sometimes 1 pixel wide tiles get
> clipped in a
> > strange way.
> > Pierre
> > <mailto:postgis-users-bounces at lists.osgeo.org> ] On Behalf
> > > Of Pierre Bails
> > > Sent: Wednesday, June 15, 2016 11:41 AM
> > > To: postgis-users at lists.osgeo.org <mailto:postgis-
> > > Subject: [postgis-users] Raster tile size impact results
> > > Hi all,
> > > I'm looking for get all pixel's value in a raster insert thanks
> to
> > raster2pgsql
> > > intersect by a polygon.
> > > Nevertheless, there are some things that I don't understand:
> depends
> > on tile
> > > size, I don't have the same result... The error between 2 raster
> is also
> > correlate
> > > to the pixel size (I assume it's due to the pixel number).
> > > Can you explain me how the tile size can influence the final
> result ?
> > > Here is the query :
> > > SELECT DISTINCT SUM((px).val)
> > > FROM(
> > > SELECT *
> > > FROM mns INNER JOIN
> st_setsrid(st_geomfromgeojson('{"type":"Polygon","coordinates":[[[x,y],[x,y],[x
> > > ,y] ]]}'), 4326) as geom on ST_Intersects(mns.rast, geom)
> > > ) AS clip, ST_PixelAsCentroids (ST_Clip(clip.rast, clip.geom),1)
> AS px;
> > > DSM px size 70cm:
> > > raster2pgsql -a -t 250x250 -s 4326 -F pathToDSM.tiff dsmTable
> (result:
> > 46 347
> > > 846)
> > > raster2pgsql -a -t 50x50 -s 4326 -F pathToDSM.tiff dsmTable :
> 46 382
> > 873
> > > Difference: 35027
> > > DSM px size 20cm :
> > > raster2pgsql -a -t 250x250 -s 4326 -F pathToDSM.tiff dsmTable :
> 567
> > 505 888
> 596
> > 897 610
> > > Difference: 29 391 722
> > > If we considere 250x250's result as reference, there is a
> difference of
> > 0.07% in
> > > the first case, and 5% in the second. If the polygon area
> increases, the
> > error rate
> > > increases.
> > > Thank you,
> > > Pierre
> > postgis-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160718/60fc3b65/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160718/60fc3b65/attachment.png>
