[postgis-users] PostGIS raster data restore issue
Regina Obe lr at pcorp.us
Wed Jul 27 13:15:27 PDT 2016
1.       I'd like it to be in September or some time before PostgreSQL 9,6,
but we'll see -
http://lists.osgeo.org/pipermail/postgis-devel/2016-July/025872.html  (still
some loose ends to button up)
2.       What sort of problems did you have?  It should work if you create
extension first, run the set path script and restore the data.  That's the
way I do it.
If you are in a rush you could hack your share/extensions/postgis-2.2.2.sql
file
Basically just copy the contents of share/contrib/postgis-2.2/
rtpostgis_proc_set_search_path.sql  to the end of the extension
postgis-2.2.2.sql  and postgis.sql extension scripts.
That way when the restore runs CREATE EXTENSION postgis, it will
automatically fix the paths of functions so the constraints don't fail when
they are called.
Then your create database and load data in one call should work.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Kevin Berger
Sent: Wednesday, July 27, 2016 10:18 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] PostGIS raster data restore issue
Thanks Regina, that helps.
1.       When will PostGIS 2.3 be available?
2.       FYI - although custom might be preferred, we had problems restoring
custom backup. We were able to restore the backup in plain text format
without issue. Our database is approximately 30 GB.
Of Regina Obe
Sent: July 25, 2016 15:42
To: 'PostGIS Users Discussion'
Unfortunately you have to create the database first.  I'm working on fixing
this for PostGIS 2.3 so you can do without creating db first, but for
PostGIS 2.2.2 steps would be
1)      Do your backup with pg_dump.exe (custom is preferred over plain
text)
2)      Create new database, install postgis extension
3)      Run the share/contrib/postgis-2.2/
rtpostgis_proc_set_search_path.sql  (note this script is there for PostGIS
2.2.2+)
4)      Restore your data as usual with pg_restore (if custom backup)  or
psql if plain text.
Hope that helps,
Regina
 <http://www.postgis.us> http://www.postgis.us
 <http://postgis.net> http://postgis.net
From: postgis-users [ <mailto:postgis-users-bounces at lists.osgeo.org>
mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Kevin Berger
Sent: Monday, July 25, 2016 1:06 PM
To:  <mailto:postgis-users at lists.osgeo.org> postgis-users at lists.osgeo.org
Subject: [postgis-users] PostGIS raster data restore issue
We want to test our PostGIS Version 2.2.2.1/PostgreSQL 9.5.2.1 restore. We
have raster data loaded into the database.
The backup command we are using is: pg_dump.exe -c -C (We specify -C as we
want the SQL for creating databases to be in the dump file - we want to
simplify the restore operation by having the database automatically created
as opposed to having to create an empty database then restore the data into
it). The dump file is 32 GB so modifying the dump file in Notepad++ is not
an option.
The restore command we are using is: psql -U postgres -f <dumpfile>.
However, we get several restore errors such as:
ERROR:  function st_bandmetadata(public.raster, integer[]) does not exist
I am thinking that the only thing we can do is to create an empty database
then restore the data into it (which as I mentioned adds more steps to
restore). Is my rationale correct?
NOTE: the restore does work fine on a database that does not contain raster
data.
Kevin
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160727/8ba9689b/attachment.html>
