[postgis-users] Point In Polygon Update Query
Birgit Laggner
birgit.laggner at thuenen.de
Wed Jun 1 08:17:08 PDT 2016
Hi Chris,
for the warning if a user is within a mile of the warned area, you could
use ST_DWithin instead of ST_Within.
Since you have EPSG 4326, I would convert the geometries into geography
types because then you can define the distance in meters (not in
degrees), perhaps like:
ST_DWithin(mastergistmp.geom::geography, wwmaster.geom::geography, 1610.0)
Otherwise your UPDATE queries look fine for me...
Regards,
Birgit
Am 27.05.2016 um 02:04 schrieb Chris B:
> I'm trying to put what the warning is for the point in the polygon, I
> have my wwmaster which is where all the warnings are stored, my
> mastergistmp where my users are stored, I know if a user is in a
> severe thunderstorm warning and a tornado warning the tornado warning
> will override the severe storm warning which is what I want does
> anyone see anything wrong with this I think I am missing some users in
> the warned area. everything is epsg 4326 I would like to also make it
> where users with in a mile of the warned area are updated with the
> information I've tried st_buffer and have had trouble with it. I'm
> updating the mastergistmp.warn or thats what I'm shooting for.
> UPDATE mastergistmp SET warn = wwmaster.prod_type FROM wwmaster WHERE
> wwmaster.prod_type = 'Flash Flood Warning' and
> ST_Within(mastergistmp.geom,wwmaster.geom);
> wwmaster.prod_type = 'Severe Thunderstorm Warning' and
> wwmaster.prod_type = 'Tornado Warning' and
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160601/fa26bdee/attachment.html>
