[postgis-users] Performance external loop, WHERE IN (values), stored procedure or else to pass data to SQL query
Leknín Řepánek godzilalalala at gmail.com
Mon Jun 13 11:46:53 PDT 2016
Python Array -> geometry(POINT, [SRID])[] -> unnest, you can use unnest
in CTE
something like
WITH cte AS (
	SELECT unnest(array['POINT(1 1)'::geometry ......]) pnt
SELECT * FROM t JOIN cte ON ST_....
Milions of points aren`t big data, if it is slow, maybe you should check
your indexes.
On Mon, Jun 13, 2016 at 08:08:34AM -0700, Michal Seidl wrote:
> Hello,
> I have probably simple question but I am stuck. I have table with about 1E6
> points in table. I have about hundreds of points in Python array. How to
> pass these points into Postgis SQL query to check against table (if the same
> point exist) with millions points?
> I started with Python loop to check every point individually but it is slow.
> I have found lots of receipts how to fight with large data but they have to
> be already in database.
> Which way is good for this situation?
> - create temporary table and firstly insert points into DB
> - try to manage Python not to close connection and send SQL query with each
> point fast
> - try to push all points in one query? How?
> - write stored procedure that will accept array of data?
> - anything else?
> May be it is more general SQL questions, but i am working with points.
> Thanks for advice Michal
> View this message in context: http://postgis.17.x6.nabble.com/Performance-external-loop-WHERE-IN-values-stored-procedure-or-else-to-pass-data-to-SQL-query-tp5010138.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
