[postgis-users] Raster SQL to separate high value areas
Regina Obe lr at pcorp.us
Wed Mar 9 04:03:42 PST 2016
You probably want to use ST_Reclass  and then ST_DumpAsPolygons.
http://postgis.net/docs/manual-2.2/RT_ST_Reclass.html - this will reduce
your pixels into a binary of above 70% , not above 70%
http://postgis.net/docs/manual-2.2/RT_ST_DumpAsPolygons.html would then give
you two sets of polygons with the two new pixel values.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of liglio at pobox.com
Sent: Tuesday, March 08, 2016 3:10 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Raster SQL to separate high value areas
I am trying to separate areas of high value of lightning probability (above
70%) in a Raster and calculate their centroids. I successfully loaded a
GeoTiff raster image (one band, gray scale, 982x1108 pixels) in PostgreSQL
9.5 (Postgis 2.2.1). I see the SQL results in OenJump 1.9.
I used the next SQL, but the function ST_PixelAsPoints result in a geometry
points which are of the pixel's upper-left corner. I am not sure that is the
right way to do, because of that displacement. Can I do without this
transformation raster-geometry ?
Thanks.
SELECT row_number() over () AS id,
  ST_NumGeometries(gc),
  gc AS geom_collection,
  ST_Centroid(gc) AS centroid
FROM (
  SELECT unnest(ST_ClusterWithin(geom, 0.1)) AS gc
  FROM (SELECT (ST_PixelAsPoints(rast, 1)).*
    FROM tb_lightningprob) foo
    WHERE val > 0.7
) f;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160309/422be0ae/attachment.html>
