[postgis-users] Slow performance when selecting a geometry column
David Robison David.Robison at q-free.com
Thu Mar 17 17:57:58 PDT 2016
I am having an issue with a postgis database with the time it takes to query the geometry column. The query selects 8000 records. The time to retrieve the records when not returning the geometry column is about 100ms. However, the time for the same query when requesting the geometry column takes about 9 seconds.  Any thoughts on how I can improve the performance reading the geometry column from a postgis database? I am using PostgreSQL 9.4 and Postgis 22.1.
Thanks, David
David Robison
Principal System Engineer
O. +1 757 546 3401
M. +1 757 286 0022
david.robison at q-free.com<mailto:david.robison at q-free.com>
www.q-free.com/openroads<http://www.q-free.com/openroads>
Q-Free Open Roads
103 Watson Road
Chesapeake VA 23320
[cid:image002.png at 01D15905.23A1F460]
This email communication (including any attachments) may contain confidential and/or privileged material intended solely for the individual or entity to which it is addressed. If you are not the intended recipient, please delete this email immediately.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160318/1c032598/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160318/1c032598/attachment.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160318/1c032598/attachment-0001.png>
