[postgis-users] Line within range of another line?
Ahmet Temiz
ahmettemiz88 at gmail.com
Tue Nov 1 23:58:37 PDT 2016
Thank you,
it was great help.
particularly your section worked well and helpful ( since I am going to
create geojson outcome from this sql for web app):
And I would think you would want one record per road so the union should be
done after, so the below would make more sense.
SELECT road.gid, ST_Union(ST_Intersection(road.the_geom,
ST_Buffer(fault.the_geom, 100) ) ) as road_fayBuffer
FROM road4analyse as road
INNER JOIN fault4analyse AS fault
ON ST_DWithin(road.the_geom, fault.geom, 100 )
GROUP BY road.gid
I used ST_Union because fault lines are so scattered (roads are as well)
and buffers look weird. I preferred more conservative approach by creating
complete buffer zone. I thought at least one of the geometry should be
simple.
on the subject of correctness of distance calculation, how about using
epsg:3857. You see
I directly use geometries in 3857. Do you recommend me transform to
geography for correct distance calculation?
thank you again
regards
thanks again.
On Mon, Oct 31, 2016 at 11:39 PM, Regina Obe <lr at pcorp.us> wrote:
> Temiz,
> Good question. They will yield similar results, but not exactly the same
> 1) When you do a buffer, it's an approximation since it uses by
> default 8 segments to approximate a quarter circle. That said, it's
> possible you will get a different count of lines than you would with
> ST_DWithin and the ST_DWithin answer would be more correct.
> 2) Unfortunately if you do need to return that portion of your line
> that intersects your buffer, you would need the ST_Buffer you have and deal
> with the less the accurateness of it if it's an issue.
> 3) Have you compared the performance of both? Your faultbuffer
> would not be able to utilize an index on the fault4analyse table, where as
> the ST_DWithin approach could.
> 4) It would also be interesting to compare the performance
> differences. In some cases using ST_Intersects with buffer is faster than
> using ST_Dwithin since GEOS has some special optimizations that I think
> ST_Dwithin lacks, but ST_DWithin would need to do less work up front than
> buffer (which could be huge for large geometries) and a buffered geom can't
> use index of underlying table.
> I think when you buffer depending on the size of your buffer and the
> jagged edges you have in fault, you may end up with a simpler geometry that
> would require less work for ST_Intersects / ST_Dwihin.
> It's also not clear to me why you are doing a ST_Union (do you have
> multiple fault lines with same gid? ) if not then that union is not
> necessary.
> be done after, so the below would make more sense.
> GROUP BY road.gid
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Ahmet Temiz
> *Sent:* Monday, October 31, 2016 3:59 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] Line within range of another line?
> Thank you,
> It was great help.
> Later, I had built this:
> WITH faultbuffer as (
> SELECT gid,ST_Union(St_Buffer(the_geom,100)) as geom from
> fault4analyse group by gid
> SELECT road.gid,ST_Intersection(road.the_geom,faultbuffer.geom ) as
> road_fayBuffer from road4analyse as road , faultbuffer
> WHERE ST_Intersects(road.the_geom, faultbuffer.geom )
> and it is reasonably fast.
> Does it do same thing you have offered ?
> kind regards
> On Sun, Oct 30, 2016 at 10:55 AM, Regina Obe <lr at pcorp.us> wrote:
> Use ST_DWithin (works for both geography and geometry) and any kind of
> geometry, not just lines .
> My example is for geography since units are always in meters. For
> geometry units you have to specify based on your spatial_ref_sys and
> geometries have to have same spatial ref sys
> something like below will return all roads that are within 100 meters of a
> fault line
> SELECT l.gid, l.geog
> FROM roads As l
> WHERE EXISTS (SELECT 1 FROM fault_lines As fl WHERE ST_DWithin(fl.geog,
> l.geog, 100) );
> If you need to know the exact fault lines, do a JOIN instead – keep in
> mind if a road is close enough to more than one fault line, it will be
> duplicated
> SELECT l.gid, l.geog, fl.name, ST_Distance(l.geog, fl.geog) AS dist
> FROM roads AS l INNER JOIN fault_lines AS fl ON (ST_DWithin(fl.geog,
> l.geog, 100) );
> If you want jus the closes fault line within 100 meters use DISTINCT ON
> SELECT DISTINCT ON(l.gid) l.gid, l.geog, fl.name, ST_Distance(l.geog,
> fl.geog) AS dist
> l.geog, 100) )
> ORDER BY l.gid, dist;
> Hope that helps,
> Regina
> http://www.postgis.us
> http://www.paragoncorporation.com
> http://postgis.net
> *Sent:* Sunday, October 30, 2016 2:59 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>; PostGIS
> Users Discussion <postgis-users at postgis.refractions.net>
> *Subject:* [postgis-users] Line within range of another line?
> Hi,
> How can I find Line within range of another line?
> I mean I try to find line section within certain range of another line.
> For example, road lines close to fault lines.
> Ps : I know that using st_buffer causes performance issue.
> Can you give any advice?
> Regards
> Ahmet Temiz
> Jeoloji Müh.
> Afet ve Acil Durum Yönetimi Başkanlığı
> Bilgi İşlem Dairesi Başkanlığı-CBS Grubu
> ________________________
> Ahmet Temiz
> Geological Eng.
> Information Systems - GIS Group
> Disaster and Emergency Management
> of Presidency
> postgis-users mailing list
> http://lists.osgeo.org/mailman/listinfo/postgis-users
> Ahmet Temiz
> Jeoloji Müh.
> Ahmet Temiz
> Geological Eng.
> of Presidency
Ahmet Temiz
Jeoloji Müh.
Ahmet Temiz
Geological Eng.
of Presidency
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161102/723f5c6a/attachment.html>
