[postgis-users] raster query
Birgit Laggner
birgit.laggner at thuenen.de
Thu Nov 3 05:20:00 PDT 2016
Hi Stephen,
here my proposed solution (untested!!)
DO $$
DECLARE r record; doy date;
BEGIN
FOR r IN (SELECT DISTINCT ST_Value(rast,x,y) AS obs_date FROM
doy_raster, generate_series(1,(SELECT ST_Width(rast) FROM doy_raster))
AS x, generate_series(1,(SELECT ST_Height(rast) FROM doy_raster)) AS y) LOOP
doy := r.obs_date;
EXECUTE
'INSERT INTO accum_risk (obs_date, rast)
SELECT '||doy||',
ST_Union(ST_MapAlgebra(a.rast, b.rast,
''CASE WHEN [rast2]='||quote_literal(doy)||' THEN
[rast1] ELSE 0 END'',
''64BF'',''INTERSECTION''),''SUM'')
FROM daily_risk AS a, doy_raster AS b
WHERE a.obs_date BETWEEN '||quote_literal(doy)||'::date - ''60
days''::interval AND
'||quote_literal(doy);
END LOOP;
END $$;
The idea is to loop over the all existing observation dates from
doy_raster and use ST_MapAlgebra to limit the raster cells from
daily_risk raster to those intersecting with raster cells from
doy_raster with the corresponding observation date for the current loop.
As already mentioned, the code is not tested (because I don't have
similar datasets available)...
Regards,
Birgit
Am 02.11.2016 um 21:51 schrieb Stephen Crawford:
> Hi All,
> I am hoping somebody can help me with a query. I have a table of
> rasters where each record is date ("obs_date") and raster containing a
> risk value of 0 or 1. My easy, successful query to accumulate the
> risk values over the previous 60 days is:
> SELECT '1979-07-15', ST_Union(rast,'SUM')
> FROM daily_risk
> WHERE obs_date BETWEEN '1979-05-16' AND '1979-07-15';
> My final goal--for which I am asking help--is similar to the above
> query, but it will reference another raster table. This table has for
> each grid cell a value for the day of year (DOY) from which the 60 day
> accumulation should be made. Conceptually:
> FOR EACH doy_cell IN doy_raster
> SELECT ST_Union(rast,'SUM')
> FROM daily_risk
> WHERE obs_date BETWEEN doy-60 AND doy;
> Any help is greatly appreciated.
> Thanks,
> Steve
> Stephen Crawford
> Center for Environmental Informatics
> The Pennsylvania State University
> src176 at psu.edu
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161103/ccef71b4/attachment.html>
