[postgis-users] raster query
Stephen Crawford
src176 at psu.edu
Fri Nov 4 07:45:18 PDT 2016
I had to make just a few minor adjustments, only about casting types
which you couldn't have know about anyway. Worked well. Many Thanks.
On 11/3/2016 8:20 AM, Birgit Laggner wrote:
> Hi Stephen,
> here my proposed solution (untested!!)
> DO $$
> DECLARE r record; doy date;
> BEGIN
> FOR r IN (SELECT DISTINCT ST_Value(rast,x,y) AS obs_date FROM
> doy_raster, generate_series(1,(SELECT ST_Width(rast) FROM doy_raster))
> AS x, generate_series(1,(SELECT ST_Height(rast) FROM doy_raster)) AS
> y) LOOP
> doy := r.obs_date;
> EXECUTE
> 'INSERT INTO accum_risk (obs_date, rast)
> SELECT '||doy||',
> ST_Union(ST_MapAlgebra(a.rast, b.rast,
> ''CASE WHEN [rast2]='||quote_literal(doy)||' THEN
> [rast1] ELSE 0 END'',
> ''64BF'',''INTERSECTION''),''SUM'')
> FROM daily_risk AS a, doy_raster AS b
> WHERE a.obs_date BETWEEN '||quote_literal(doy)||'::date - ''60
> days''::interval AND
> '||quote_literal(doy);
> END LOOP;
> END $$;
> The idea is to loop over the all existing observation dates from
> doy_raster and use ST_MapAlgebra to limit the raster cells from
> daily_risk raster to those intersecting with raster cells from
> doy_raster with the corresponding observation date for the current loop.
> As already mentioned, the code is not tested (because I don't have
> similar datasets available)...
> Regards,
> Birgit
> Am 02.11.2016 um 21:51 schrieb Stephen Crawford:
>> Hi All,
>> I am hoping somebody can help me with a query. I have a table of
>> rasters where each record is date ("obs_date") and raster containing
>> a risk value of 0 or 1. My easy, successful query to accumulate the
>> risk values over the previous 60 days is:
>> SELECT '1979-07-15', ST_Union(rast,'SUM')
>> FROM daily_risk
>> WHERE obs_date BETWEEN '1979-05-16' AND '1979-07-15';
>> My final goal--for which I am asking help--is similar to the above
>> query, but it will reference another raster table. This table has
>> for each grid cell a value for the day of year (DOY) from which the
>> 60 day accumulation should be made. Conceptually:
>> FOR EACH doy_cell IN doy_raster
>> SELECT ST_Union(rast,'SUM')
>> FROM daily_risk
>> WHERE obs_date BETWEEN doy-60 AND doy;
>> Any help is greatly appreciated.
>> Thanks,
>> Steve
>> Stephen Crawford
>> Center for Environmental Informatics
>> The Pennsylvania State University
>> src176 at psu.edu
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/postgis-users
Stephen Crawford
src176 at psu.edu
814.865.9905
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161104/cd5a7ae1/attachment.html>
