[postgis-users] problems while upgrading postgis
Paolo Importuni
imppao at gmail.com
Wed Nov 9 00:45:59 PST 2016
Hi all,
I am trying to migrate my postgres/postgis instance from 2.0 to 2.2.2
The new postgis.so library is in the right place and I found the right
migration script postgis-2.0.0--2.2.2.sql.
I successfully upgraded three db instances by using the "ALTER EXTENSION
postgis UPDATE TO '2.2.2';" command, but it failed on one instance.
As far as I see, the problem might be that the postgis extension wasn't
created using the "CREATE EXTENSION POSTGIS" script, but maybe by some
other methods.
If I try to create the extension, it fails saying "ERROR: type "spheroid"
already exists"; if I try to upgrade it fails, saying that the extension
postgis does not exist.
If I create a new db instance, create a new extension and then upgrade it
to postgis 2.2. everything works fine.
Is a there a way to sort it out?
Thanks and regards
Paolo
Paolo Importuni
Software Analyst and Developer
Modena, Italy
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161109/3c0df873/attachment.html>
