[postgis-users] problems while upgrading postgis
Paolo Importuni imppao at gmail.com
Wed Nov 9 02:44:53 PST 2016
Hi strk,
I've just tried but it complains that
"ERROR:  type "raster" does not exist"
Thanks for helping
Paolo
Paolo Importuni
Software Analyst and Developer
Modena, Italy
2016-11-09 11:12 GMT+01:00 Sandro Santilli <strk at kbt.io>:
> On Wed, Nov 09, 2016 at 09:45:59AM +0100, Paolo Importuni wrote:
> > I am trying to migrate my postgres/postgis instance from 2.0 to 2.2.2
> > The new  postgis.so library is in the right place and I found the right
> > migration script postgis-2.0.0--2.2.2.sql.
> > I successfully upgraded three db instances by using the "ALTER EXTENSION
> > postgis UPDATE TO '2.2.2';"  command, but it failed on one instance.
> > As far as I see, the problem might be that the postgis extension wasn't
> > created using the "CREATE EXTENSION POSTGIS"  script, but maybe by some
> > other methods.
> > If I try to create the extension, it fails saying "ERROR: type "spheroid"
> > already exists"; if I try to upgrade it fails, saying that the extension
> > postgis does not exist.
> > If I create a new db instance, create a new extension and then upgrade it
> > to postgis 2.2. everything works fine.
> > Is a there  a way to sort it out?
> To turn your non-extension install to an extension one, try this:
>   CREATE EXTENSION POSTGIS VERSION '2.0.0' FROM 'unpackaged';
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   https://strk.kbt.io/services.html
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161109/87544445/attachment.html>
