[postgis-users] problems while upgrading postgis
Paolo Importuni
imppao at gmail.com
Wed Nov 9 09:33:28 PST 2016
Hi strk,
still problems, it says:
"You need to install postgresql-server-dev-X.Y for building a server-side
extension or libpq-dev for building a client-side application"
Do I need to apt-install postgresql-server-dev-X.Y? What's the use?
Thanks again
Paolo
2016-11-09 12:06 GMT+01:00 Sandro Santilli <strk at kbt.io>:
> On Wed, Nov 09, 2016 at 11:44:53AM +0100, Paolo Importuni wrote:
> > Hi strk,
> > I've just tried but it complains that
> > "ERROR: type "raster" does not exist"
> This is because postgis _EXTENSION_ is forced to have
> also raster in it :(
> So the fix is for you to load raster script for 2.0.0
> psql -f `pg_config --sharedir`/contrib/postgis-2.0/rtpostgis.sql <yourdb>
> --strk;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161109/fe29deed/attachment.html>
