[postgis-users] How does one make sense out of the postgis garden tests results?
sablok
sablok at amazon.com
Fri Nov 11 10:36:04 PST 2016
So I am running garden tests for postgis to see if there are any tests that
are crashing the server instance, but I am totally bamboozled by the amount
of test cases that are run and can't seem to decipher the results as to if
it was positive or negative, I keep on getting errors like the following
though:
HINT: No function matches the given name and argument types. You might need
to add explicit type casts.
QUERY: SELECT ST_Zmflag(foo1.the_geom) As result
FROM ((SELECT
ST_MakePolygon(ST_GeomFromText('LINESTRING(1 2, 1 2,1 2, 1 2)',4326)) As
the_geom
UNION ALL SELECT
ST_MakePolygon(ST_GeomFromText('LINESTRING(1 2, 1 2,1 2, 1 2, 3 2, 1
2)',4326)) As the_geom ) ) As foo1 LIMIT 3;
psql:/tmp/geo_torturetest.sql:1984091: ERROR: current transaction is
aborted, commands ignored until end of transaction block
psql:/tmp/geo_torturetest.sql:1984102: ERROR: function unlockrows(unknown)
does not exist
LINE 1: SELECT UnlockRows('monkey') As output;
QUERY: SELECT UpdateGeometrySRID('test', 'test', 'test', 3395) As output;
psql:/tmp/geo_torturetest.sql:1984130: ERROR: current transaction is
psql:/tmp/geo_torturetest.sql:1984141: ERROR: function
updategeometrysrid(unknown, unknown, unknown, unknown, integer) does not
exist
LINE 1: SELECT UpdateGeometrySRID('test', 'test', 'test', 'test', 3...
Can anyone suggest me how to make sense out of these tests or if there is
any other way I can test postgis to gain some confidence?
View this message in context: http://postgis.17.x6.nabble.com/How-does-one-make-sense-out-of-the-postgis-garden-tests-results-tp5010601.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
