[postgis-users] estimated extent and EPSG:5514
Martin Landa
landa.martin at gmail.com
Tue Nov 22 00:29:14 PST 2016
2016-11-21 17:15 GMT+01:00 Sandro Santilli <strk at kbt.io>:
hm, I tested simplified workflow on personal computer with GDAL 2.2dev
and PostGIS 2.4:
$ wget http://vdp.cuzk.cz/vymenny_format/soucasna/20161031_ST_UKSH.xml.gz
$ createdb test_5514
$ psql test_5514 -c"create extension postgis"
$ wget https://epsg.io/5514.sql
$ psql test_5514 -f 5514.sql
$ ogr2ogr -f PostgreSQL PG:dbname=test_5514 20161031_ST_UKSH.xml.gz kraje
$ psql test_5514 -c"select st_extent(originalnihranice) from kraje"
BOX(-904584.86 -1227295.83,-431724.3 -935236.59)
psql test_5514 -c"vacuum analyze kraje"
psql test_5514 -c"select st_estimatedextent('kraje', 'originalnihranice')"
BOX(-906949.1875 -1228756.125,-429359.96875 -933776.25)
Then on the server (where I found this issue) I am able to reproduce the error:
sudo psql test_5514 -U postgres -c"select st_estimatedextent('kraje',
st_estimatedextent
BOX(-909107.8125 -1233432.375,4522.92431640625 6136.4794921875)
On the server I have GDAL 2.1.2 and PostgreSQL 9.1, PostGIS 2.1.1.
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
