[postgis-users] Install PostGIS without StackBuilder - Windows
Regina Obe lr at pcorp.us
Wed Nov 23 12:35:02 PST 2016
Theo,
Tumasgiu is right, it should be pretty straightforward if you use the exe.  All the application stackbuilder does is downloads and runs that same exe.
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Tumasgiu Rossini
Sent: Wednesday, November 23, 2016 11:54 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Install PostGIS without StackBuilder - Windows
Hello.
Using the wizard of postgis-bundle-pg96x64-setup-2.3.0-1.exe <http://download.osgeo.org/postgis/windows/pg96/postgis-bundle-pg96x64-setup-2.3.0-1.exe>  is quite easy and straighforward as far as I remember.
2016-11-23 17:22 GMT+01:00 LECHEMIA Theo <theo.lechemia at onf.fr <mailto:theo.lechemia at onf.fr> >:
Hello,
I'm trying to install PostGIS on Windows. I'm on a company computer, so we're behind a proxy which forbide the StackBuilder application to access to the PostgresSQL extension list (https://www.postgresql.org/applications-v2.xml).
 I download the binairy files of PostGIS here (http://download.osgeo.org/postgis/windows/) and I would like to install the extension manually but I don't find any documentation which explain how to do.
Is anybody already face to this problem ?
Thank you fo your answer
Théo
postgis-users mailing list
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161123/fdbcfe0c/attachment.html>
