[postgis-users] TIGER 2016 Setup Question
Regina Obe
lr at pcorp.us
Wed Nov 23 12:54:19 PST 2016
Hmm that's very odd.
I see wget for those when I run:
SELECT Loader_Generate_Script(ARRAY['CA'], 'sh');
You followed these instructions:
http://postgis.net/docs/manual-2.3/postgis_installation.html#install_tiger_geocoder_extension
If you are using pgAdmin to generate the script, make sure you have Query Editor -> Max. characters per column set to something very large.
It's usually low like 255, so most of the script would be truncated if you copied and pasted from pgAdmin.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Frank Quick
Sent: Wednesday, November 23, 2016 3:43 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] TIGER 2016 Setup Question
Regina,
Thank you for responding!
I'm definitely downloading successfully from the census site.
I'm on Mac OS X v10.11.1.
I noticed the script didn't generate any wget commands for addr/edges/features/faces.
Abe
On Wed, Nov 23, 2016 at 12:31 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Yap seems something went wrong with your load.
I get this:
rating | lon | lat | stno | street | styp | city | st | zip
0 | -122.406147398092 | 37.7853683917931 | 835 | Market | St | San Francisco | CA | 94103
(1 row)
You might want to check the folder the script downloads to and make sure it did download the addr/edges/featnames files. I've had issues with the census site in that if you download enough states, their akmai lockout thing kicks in so then you are denied from their site for a couple of days. Not sure if that is what you are running into.
Which OS are you on. It's also possible I made a mistake somewhere in the script that is affecting your OS.
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> ] On Behalf Of Frank Quick
Sent: Wednesday, November 23, 2016 2:49 PM
To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Subject: [postgis-users] TIGER 2016 Setup Question
I'm attempting to get the geocoder extension to work. When I try to geocode a common address, I get a latitude and longitude that's pretty far off and the street information is missing. Example:
SELECT g.rating, ST_X(g.geomout) As lon, ST_Y(g.geomout) As lat, (addy).address As stno, (addy).streetname As street, (addy).streettypeabbrev As styp, (addy).location As city, (addy).stateabbrev As st,(addy).zip FROM geocode('835 market street, san francisco ca 94103') AS g;
100 | -122.6939756117 | 37.7597150026058 | | | | San Francisco | CA | 94103
Here are the counts of some of the tables that I believe are/should be populated after running the loader script:
* tiger.addr: 0
* tiger.edges: 0
* tiger.faces: 0
* tiger.featnames: 0
* tiger.place: 1522
* tiger.cousub: 397
* tiger.county: 3233
* tiger.state: 56
* tiger.zip_lookup_base: 0
* tiger.zip_state: 0
* tiger.zip_state_loc: 0
The loader script appears to not be downloading a few datasets:
* www2.census.gov/geo/tiger/TIGER2016/ADDR <http://www2.census.gov/geo/tiger/TIGER2016/ADDR>
* www2.census.gov/geo/tiger/TIGER2016/EDGES <http://www2.census.gov/geo/tiger/TIGER2016/EDGES>
* www2.census.gov/geo/tiger/TIGER2016/FEATNAMES <http://www2.census.gov/geo/tiger/TIGER2016/FEATNAMES>
* www2.census.gov/geo/tiger/TIGER2016/FACES <http://www2.census.gov/geo/tiger/TIGER2016/FACES>
Does any one know if I'm missing crucial data? If so, is it possible to back fill from previous years? If not, what else could be going on here?
Thanks
postgis-users mailing list
http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161123/6a8a0336/attachment.html>
