[postgis-users] Fwd: Reg: Get features in a bounding box
Regina Obe
lr at pcorp.us
Sun Nov 27 07:35:55 PST 2016
Manikanta,
Easiest way is to use the ST_MakeEnvelope function to convert your mins and maxes to a geometry.
http://postgis.net/docs/ST_MakeEnvelope.html
SELECT t.name, t.geom
FROM t
WHERE ST_Intersects(t.geom, ST_MakeEnvelope(MIN-X, MIN-Y, MAX-X, MAX-Y,SRID) );
Where the upper case I have you replace with your variables and t replace with your table name.
If you want completely enclosed, replace ST_Intersects with ST_CoveredBy
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Manikanta Kondeti
Sent: Saturday, November 26, 2016 3:16 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Fwd: Reg: Get features in a bounding box
Hello,
I have almost empty knowledge on postgis queries and trying to learn them. I beg your pardon if its a very simple question.
So here it is in my current project, as the subject says, I have a list of bounding box cooridnates, MIN-X, MIN-Y, MAX-X MAX-Y with the same SRID of the geom column. Now I want to query the list of features that are enclosed in this bounding box. Awaiting for a reply, thanks in advance.
Regards,
Manikanta
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161127/04483a98/attachment.html>
