[postgis-users] Converting a LineString to a CompoundCurve
Andreas Neumann
a.neumann at carto.net
Fri Oct 7 00:12:18 PDT 2016
I am trying to convert a LineString to a CompoundCurve.
I was trying ST_LineToCurve(), but it seems to return again a LineString ;-(
Casting with ::geometry(CompoundCurve,21781) doesn't work either.
Is this impossible to do or did I miss something?
The reason I want to do it, is that I have some road data which is in
CompoundCurve type. I want to use ST_LineStubstring() on this geometry,
so I use ST_CurveToLine(). I want to convert the result back into a
CompoundCurve, for being able to store it in a table which has a
constraint on CompoundCurve type.
Thank you, if you have an idea!
Andreas
