[postgis-users] Problem extracting SQL Server Geometry (or, what is the 0x character?)
Peter Devoy
peter at 3xe.co.uk
Sat Oct 15 06:55:10 PDT 2016
*0x* is the prefix used in computing to indicate the following number is
represented in base 16 (hexadecimal). WKB is Well Known Binary, you are
seeing the binary (base 2) represented in hexadecimal base (base 16).
E.g. 255 decimal = 11111111 binary = 0xFF [hexadecimal]
Kind regards
Peter
*3XE <http://3xe.co.uk/>*
P: 01326 567155
M: 07770 693662
A: 3XE Ltd
Tremough Innovation Centre
PENRYN
TR10 9TA
3XE Ltd · Registered in England and Wales · 9356871
On 15 October 2016 at 01:03, Ben Madin <ben at ausvet.com.au> wrote:
> G'day all,
> I hope a simple case of something I've missed, but we are trying to
> extract data from a SQL Server database into PostGIS use tds_fdw... the
> data in SQL Server appears to be in WKB - but when when connect to this
> field we have a precursor 0x. I can't find any references to anyone else
> suffering this problem, but that could be because I'm trying a lazy
> approach to automate retrieval of hundreds of tables using the FDW (that's
> what it is for, right?)
> I'm left with a sense that it is an encoding error between the two
> systems? I've tried making the fdw column text instead of geometry, but I
> can't get rid of the 0x, and no amount of trying to cajole the text to any
> other form makes it any happier.
> To complicate it, for testing I'm going from SQL Server 2014 (running in
> Windows 8.1 in a VM) to PostgreSQL 9.4 on a Mac (El Capitan) using tds_fdw
> compiled on the same mac. POSTGIS="2.2.2 r14797" GEOS="3.5.0-CAPI-1.9.0 r0"
> PROJ="Rel. 4.9.2, 08 September 2015" GDAL="GDAL 2.1.1, released 2016/07/07"
> LIBXML="2.7.8" LIBJSON="0.12.1" RASTER
> Any ideas gratefully received?
> cheers
> Ben
> m : +61 448 887 220
> e : ben at ausvet.com.au
> 10 High Street, Fremantle
> Western Australia
> on the web: www.ausvet.com.au
> This transmission is for the intended for a mailing list and is clearly
> never going to be confidential information. If you have received this
> transmission in error, apologies! The contents of this email are the likely
> ill-educated opinion of the writer only and are not endorsed by Ausvet
> unless expressly stated otherwise. Thanks for reading. An even bigger
> thanks for any help you can provide.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161015/7d95e1cf/attachment.html>
