[postgis-users] Problem installing postgis on centos 6.8 desktop + postgresql 93
Mike Frampton
mike_frampton at hotmail.com
Tue Oct 25 16:16:12 PDT 2016
Hi
Im trying to install postgis on to a centos 6.8 desktop server which has postgresql 93 and phpPgAdmin installed. Ive followed the instructions at
http://postgis.net/install/
but I keep running into an error related to a missing library ( libCharLS.so.1 ). i.e.
cd /tmp ; rm -rf postgis ; mkdir postgis ; cd postgis
wget https://download.postgresql.org/pub/repos/yum/9.3/redhat/rhel-6-x86_64/pgdg-centos93-9.3-3.noarch.rpm
rpm -ivh pgdg*
yum -y install postgis2_93
This gives an error
--> Processing Dependency: libCharLS.so.1()(64bit) for package: gdal-libs-1.9.2-8.rhel6.x86_64
--> Finished Dependency Resolution
Error: Package: gdal-libs-1.9.2-8.rhel6.x86_64 (pgdg93)
Requires: libCharLS.so.1()(64bit)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
I tried to manually install / reinstall the epel release but that didnt solve the issue.
rpm -e epel-release-6-8.noarch
rpm -ivh http://dl.fedoraproject.org/pub/epel/6/x86_64/epel-release-6-8.noarch.rpm
Does anyone have any pointers, can anyone provide any suggestions ?
cheers
Mike
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161025/df728153/attachment.html>
