[postgis-users] Line within range of another line?
Regina Obe
lr at pcorp.us
Sun Oct 30 00:55:36 PDT 2016
Use ST_DWithin (works for both geography and geometry) and any kind of geometry, not just lines .
My example is for geography since units are always in meters. For geometry units you have to specify based on your spatial_ref_sys and geometries have to have same spatial ref sys
something like below will return all roads that are within 100 meters of a fault line
SELECT l.gid, l.geog
FROM roads As l
WHERE EXISTS (SELECT 1 FROM fault_lines As fl WHERE ST_DWithin(fl.geog, l.geog, 100) );
If you need to know the exact fault lines, do a JOIN instead – keep in mind if a road is close enough to more than one fault line, it will be duplicated
SELECT l.gid, l.geog, fl.name, ST_Distance(l.geog, fl.geog) AS dist
FROM roads AS l INNER JOIN fault_lines AS fl ON (ST_DWithin(fl.geog, l.geog, 100) );
If you want jus the closes fault line within 100 meters use DISTINCT ON
SELECT DISTINCT ON(l.gid) l.gid, l.geog, fl.name, ST_Distance(l.geog, fl.geog) AS dist
ORDER BY l.gid, dist;
Hope that helps,
Regina
http://www.postgis.us
http://www.paragoncorporation.com
http://postgis.net
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Ahmet Temiz
Sent: Sunday, October 30, 2016 2:59 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>; PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Subject: [postgis-users] Line within range of another line?
How can I find Line within range of another line?
I mean I try to find line section within certain range of another line.
For example, road lines close to fault lines.
Ps : I know that using st_buffer causes performance issue.
Can you give any advice?
Regards
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Bilgi İşlem Dairesi Başkanlığı-CBS Grubu
________________________
Ahmet Temiz
Geological Eng.
Information Systems - GIS Group
Disaster and Emergency Management
of Presidency
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161030/1600bed3/attachment.html>
