[postgis-users] Raster time-series data
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Fri Sep 2 12:42:30 PDT 2016
Sounds reasonable to me. You could try splitting the process between your 4 or 8 processors, each importing a selection of files. Maybe this could help, maybe this could make the whole process even slower (depend on what is slow the CPU or the disk)...
If you don't necessarily need all the pixel values in the DB, try the -R option when importing. This is definitely faster.
Pierre
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
> Of Tom Cook
> Sent: Wednesday, August 31, 2016 12:46 PM
> To: postgis-users at lists.osgeo.org
> Subject: [postgis-users] Raster time-series data
> I'm trying to import (what I think of as) large timeseries of gridded data in
> postgis 2.0 (on PostgreSQL. The data comes as HDF-EOS files (basically HDF4).
> Each file has the whole grid, which is 22680 points, and 24 bands, one for each
> hour of the day. Each file covers one day, and I'm trying to import 16 years
> (5,844 files).
> My strategy at present is to put each day into a raster with 24 bands, really
> because this is the easiest to implement. So for the first file:
> raster2pgsql -I -t auto -c 'HDF4_EOS:EOS_GRID:"file1.hdf":EOSGRID:SWGDN'
> swgdn | psql
> psql -c 'alter table swgdn add raster_date date;
> psql -c 'update swgdn set raster_date = '20000101';
> And then for subsequent files:
> raster2pgsql -I -t auto -a 'HDF4_EOS:EOS_GRID:"fileX.hdf":EOSGRID:SWGDN'
> swgdn | psql
> psql -c 'update swgdn set raster_date = 'XXXXXXXX' where raster_date is null;
> In a word, it's slow. I've so far been running the import script for about an hour
> and it's processed 146 input files. I can't really quantify this, but it feels like it's
> getting slower.
> Is this a reasonable strategy for storing this data, and my performance
> expectations just unrealistic? Or is there a better structure to use for this?
> Thanks for any suggestions,
> Tom
