[postgis-users] help with a query
Jonatan Malaver
jon.malaver at shrewsburyma.gov
Wed Sep 14 08:13:38 PDT 2016
Hello again, I do not have parent line id. All I have is a starting point
from where the direction should reference.
On Wed, Sep 14, 2016 at 9:09 AM Leknín Řepánek <godzilalalala at gmail.com>
wrote:
> On Wed, Sep 14, 2016 at 12:09:23PM +0000, Jonatan Malaver wrote:
> > the reason being is that I do a network analysis by running the following
> > function:
> > WITH RECURSIVE flow(gid, geom) AS (
> > SELECT e.gid, e.geom FROM electric_line e, transformers t WHERE
> ST_Distance
> > (t.geom,ST_StartPoint(e.geom)) <= 0.01 AND t.gid=$1
> > UNION ALL
> > SELECT n.gid, n.geom
> > FROM electric_line n, flow f
> > WHERE ST_Distance(ST_EndPoint(f.geom),ST_StartPoint(n.geom)) <= 0.01
> > The problem I have is that some of the lines direction are in reversed.
> I'm
> > trying to correct them with referenced to the first line. Otherwise, I
> will end
> > up changing hundreds of lines manually.
> Manually? No. There are many of possible ways how do this by query. For
> example if you have in every line id of "parent line" you can use
> anonymous block of code by something like this.
> DO $$
> DECLARE line record;
> BEGIN
> FOR line in SELECT lines from lines ORDER BY id LOOP
> IF NOT ST_Equal(ST_startpoint(line.geom) , (SELECT
> ST_EndPoint(geom) FROM lines WHERE id = line.parent_line_id))
> THEN
> UPDATE lines SET geom = ST_Reverse(geom) WHERE id =
> line.id;
> END LOOP;
> END
> > On Tue, Sep 13, 2016 at 11:12 AM James Keener <jim at jimkeener.com> wrote:
> > Depends on what you mean by direction. If you want to grab the start
> and
> > end points (st_startpoint and st_endpoint) and check their x and y
> (st_x
> > and st_y) for some condition (both less at the end?) Then update the
> record
> > with the value of st_reverse.
> > I guess my other question is why it matters.
> > Jim
> > On September 13, 2016 8:31:07 AM EDT, Jonatan Malaver <
> > jon.malaver at shrewsburyma.gov> wrote:
> > Hello,
> > I'm trying to come up with a query that would check the
> direction of
> > a line. If the end point is not the start point of the next line
> to
> > update the line by reversing that line. Can anyone give me
> pointers on
> > how to do it?
> > Thanks,
> > Jon
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/postgis-users
> > Sent from my Android device with K-9 Mail. Please excuse my brevity.
> > Thanks,
> > Jonatan Malaver
> > Assistant Engineer of Electrical and Cable Operations
> > Shrewsbury Electric & Cable Operations
> > 100 Maple Avenue
> > Shrewsbury, MA 01545
> > Office: (508) 841-8610
> > Fax: (508) 842-9267
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160914/280ac426/attachment.html>
